Ana içeriğe geç
Mac mini Model A1176 Top Housing Replacement
Walter Galan
Walter Galan ve 6 diğer katkıda bulunanlar
En son July 10, 2024 tarihinde güncellendi
Tahmin yok
Orta
Öne Çıkan Kılavuzlar
Remove the top housing to access your mini's internals.
Neye ihtiyacın var
Aletler
  1. Mac mini Model A1176 Top Housing Replacement, Top Housing: adım 1, 2 resimden 1. Mac mini Model A1176 Top Housing Replacement, Top Housing: adım 1, 2 resimden 2.
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
    A spackle knife makes these steps go much faster.
    jouniseppanen - Yanıt
    A double sided letter opener or a thin non-serrated butter knife will suffice.
    To prenent cosmetic blemishes, place a matchbook cover or similar thin cardboard on the outer perimeter under the “jimmy”.
    Mike - Yanıt
    Despite mentioning recommended tools at the top I think it’s really worthwhile making a point about narrow Philips screwdrivers at this point before people start putting the case apart.
    Matt D - Yanıt
  2. Mac mini Model A1176 Top Housing Replacement: adım 2, 3 resimden 1. Mac mini Model A1176 Top Housing Replacement: adım 2, 3 resimden 2. Mac mini Model A1176 Top Housing Replacement: adım 2, 3 resimden 3.
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    Patience is your best friend.
    Do not insert “jimmy in too far. Marking a line from tip upwards on the tool will prevent too far insertion, possibly breaking tabs or damaging internal components.
    To prevent the cover closing back up, small strips of matchbook cover (os equivalent) can be inserted about half inch hold prevent closure.
    Mike - Yanıt
  3. Mac mini Model A1176 Top Housing Replacement: adım 3, 2 resimden 1. Mac mini Model A1176 Top Housing Replacement: adım 3, 2 resimden 2.
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini Model A1176 Top Housing Replacement: adım 4, 2 resimden 1. Mac mini Model A1176 Top Housing Replacement: adım 4, 2 resimden 2.
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini Model A1176 Top Housing Replacement: adım 5, 2 resimden 1. Mac mini Model A1176 Top Housing Replacement: adım 5, 2 resimden 2.
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini Model A1176 Top Housing Replacement: adım 6, 2 resimden 1. Mac mini Model A1176 Top Housing Replacement: adım 6, 2 resimden 2.
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
    Before reassembly, make sure no wires are sticking out.
    Line up top cover carefully. Gently press down on top cover until top and bottom fully seated.
    CAUTION! DO NOT PRESS TOO HARD ON THE COVER TO PREVENT CRACKING THE PLASTIC TOP.
    GO EASY.
    Mike - Yanıt
Sonuç
47 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Does this work to remove a disc
ajunelady6 - Yanıt
That's part of the process. After that, you will probably need to disassemble the optical drive.
Skylar -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 57
Her zaman: 31,183
