Ana içeriğe geç
MacBook Air 11" Early 2015 Right Speaker Replacement
Neye ihtiyacın var
  1. MacBook Air 11" Early 2015 Right Speaker Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2015 Right Speaker Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2015 Right Speaker Replacement, Battery Connector: adım 3, 2 resimden 1. MacBook Air 11" Early 2015 Right Speaker Replacement, Battery Connector: adım 3, 2 resimden 2.
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2015 Right Speaker Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  5. MacBook Air 11" Early 2015 Right Speaker Replacement: adım 5, 1 resimden 1.
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air 11" Early 2015 Right Speaker Replacement, Right Speaker: adım 6, 1 resimden 1.
    • Use the tip of a spudger to de-route the right speaker cable from the channel cut into the logic board.
  7. MacBook Air 11" Early 2015 Right Speaker Replacement: adım 7, 1 resimden 1.
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • Pry upward from beneath the wires.
  8. MacBook Air 11" Early 2015 Right Speaker Replacement: adım 8, 2 resimden 1. MacBook Air 11" Early 2015 Right Speaker Replacement: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
    • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
  9. MacBook Air 11" Early 2015 Right Speaker Replacement: adım 9, 1 resimden 1.
    • Remove the right speaker from the upper case.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
476.230 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
124 Üyeler
24.282 adet Kılavuz yazıldı
1Rehber Yorum
I normally am very selfish like most of us who are looking for hardware or software support and forget or ignore the
Hardware support engineers who have accomplished training and experience and are kind enough to share with us.
My Comments are related to the methodical format which makes it so much easier to follow, by enumerating the
steps. In addition, this is superior, Identifying the Tools we need to use to do these tasks. Most service manuals
forget to do it or just assume that we know. Thank You so much for this great guide, it has allowed me
to repair and fix multiple issues that I have had with my Apple MacBook Air A1465. It is still working fine because
of this guide and comments.
Zuhirah R Rasulalah - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 74
Her zaman: 3,038
