Ana içeriğe geç
MacBook Air 11" Late 2010 Battery Replacement
Neye ihtiyacın var
    1. MacBook Air 11" Late 2010 Battery Replacement, Lower Case: adım 1, 1 resimden 1.
      Bu adımda kullanılan alet:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Before proceeding, close your computer and lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Air 11" Late 2010 Battery Replacement: adım 2, 1 resimden 1.
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Air 11" Late 2010 Battery Replacement, Battery: adım 3, 2 resimden 1. MacBook Air 11" Late 2010 Battery Replacement, Battery: adım 3, 2 resimden 2.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Air 11" Late 2010 Battery Replacement: adım 4, 1 resimden 1.
      • Remove the following five screws securing the battery to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Air 11" Late 2010 Battery Replacement: adım 5, 1 resimden 1.
      • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      FixBot'a Sor
      Yorum Ekle
Sonuç
119 farklı kişi bu kılavuzu tamamladı.
21Kılavuz Yorumları
This looks like an excellent how-to! Especially liked the location illustration of different length battery screws.
My only comment would be to have a tray ready to put the screws in - looks like they could easily be lost.
Leonard - Yanıt Paylaş
Now my touchpad isn't working as well as before. Any ideas why?
todd rumaner - Yanıt Paylaş
Dead on Accurate. Was very easy. I would change the rating from moderate to easy. The hardest part is getting the correct screw drivers.
Phil Blake - Yanıt Paylaş
hello, is there any difference between A1370 (late 2010) battery part and a A1370 (2011) battery?
Carlo Mejia - Yanıt Paylaş
I'm also wondering the same thing. Did you find the answer to your question? Thank you.
swj.sean - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 39
Son 30 gün: 152
Her zaman: 112,949
