Giriş
Use this guide to replace a damaged logic board.
Neye ihtiyacın var
Bu adımda kullanılan alet:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Use the flat end of a spudger to free the adhesive loop securing the I/O board power cable to the upper case.
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
29 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
I concur this does not match the A1465 board in some areas. The Airport / Bluetooth connectors are in a different spot and the heatsink is different. Perhaps some photos from another board were used in a few places. The rest appears to be the same, so far.
