Giriş
Use this guide to replace the left speaker.
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Use the flat end of a spudger to pry the I/O board cable connector up off its socket on the I/O board.
Bend the cable away from the I/O board.
Bir başkası bu kılavuzu tamamladı.
