Giriş
Use this guide to upgrade or replace the solid-state drive in a MacBook Air 11” Mid 2013. This MacBook Air uses a proprietary storage drive connector, and is therefore not compatible with common M.2 drives without the use of an adapter.
Before you perform this repair, if at all possible, back up your existing SSD. Then, either familiarize yourself with internet recovery or create a bootable external drive so you’ll be ready to install macOS onto your new drive and migrate your data to the new SSD.
Finally, we strongly recommend installing macOS 10.13 High Sierra (or a later macOS) before replacing the original SSD from your MacBook Air. Most new SSDs require updated storage drivers not found in versions of macOS prior to High Sierra.
Neye ihtiyacın var
Bu adımda kullanılan alet:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
52 farklı kişi bu kılavuzu tamamladı.
15Kılavuz Yorumları
I wonder if someone can help me - I completed the installation and rebooted from a clone of the original drive on an external USB disk. I tried to clone that back onto the new SSD but that failed and now the new SSD does not appear on the desktop and does not appear in Disk Utility. Its not being recognised when I boot up. Do you have any ideas how I can get it to reappear - I assume the format is lost so is there a way to reformat?
Can i upgrade my ssd drive from 128 to 1TB ?
i want to know too
