Aletler
Parçalar
MacBook Air Late 2010 - Working - High Sierra, Catalina, M2 Samsung Evo 860, Adapter
MacBook Air 2011 - Unknown
MacBook Air 2012 - Unknown
MacBook Air 2013 - Unknown
MacBook Air 2014 - WD_black 500 + Sintech adapter, running MacOS Big Sur
MacBook Air Early 2015 - WORKING- Mojave 10.14.3 to Big Sur 11.0.1- Crucial P1 SSD NVME, Adapter.
MacBook Air 2017 - WORKING - High Sierra, Catalina 10.15.3 - Samsung Evo 960, Adapter.
MacBook Air 2018 and forward - will not work, No removable drive
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Carefully insert the new SSD into the adapter, using the length of old drive as a reference for when the SSD is fully in the adapter. The lengths should be the same.
Insert the SSD and the adapter into the Socket, pushing inward in a straight fashion.
When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
From a Terminal, use the following command to disable hibernation: ----"sudo pmset -a hibernatemode 0" ---- If you later want to enable hibernation, use: "sudo pmset -a hibernatemode 3"
25 farklı kişi bu kılavuzu tamamladı.
39 Yorum
I have a Macbook air 2017 1466this model https://support.apple.com/kb/SP753?local...
macOS Mojave ver 10.14.6. will your manual work?
Yes, this Manual will work for your Device.
Greets - Maik
Hi!.. Does anyone knows if the crucial SSD will work with the Macbook Air 13” 2017?
Thanks!
