Giriş
Use this guide to replace the heat sink.
Be sure to apply a new layer of thermal paste before reinstalling your heat sink.
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
Remove the two 4.9 mm T8 Torx screws securing the antenna cable retainer on the left display hinge to the upper case.
Remove the heat sink from the logic board.
19 farklı kişi bu kılavuzu tamamladı.
3 Comments
Hello everyone, if you are removing heatsink only to change thermal paste - the main problem is 5th screw near i/o board, to get him you just need to disconnect antenna cable, it covers this screw. You can see its connectors on pic 20 , left side. so you don't need to remove fans, cables, i/o board to get heatsink. The biggest problem for me was to plug in again 2 antenna connectors after job was done. they are tiny that's why so difficult to plug in. but this way reduces risk to damage anything.
Removing 2 antenna connectors has less chance that anything goes wrong vs i/o cable, fan cable, i/o board etc
Wow, thank you. I just did this and steps 4-17 can be ignored unless you really want to clean that fan out. Carefully disconnecting the 2 antenna wires in pic 20 as stated and giving them slack allows access to screw 5 of the heatsink in Step 18. Well engineered.
Jason -
Hi, when I turn on the Mac this parte gets really hot, it burns. Also, sometimes the Mac suddenly turn off. Do you think it just need new thermal paste? I have never change ir.
