Ana içeriğe geç
MacBook Air 2022 (M2) Headphone Jack Replacement
Neye ihtiyacın var
  1. MacBook Air 2022 (M2) Headphone Jack Replacement, Prepare your Macbook Air for disassembly: adım 1, 3 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Prepare your Macbook Air for disassembly: adım 1, 3 resimden 2. MacBook Air 2022 (M2) Headphone Jack Replacement, Prepare your Macbook Air for disassembly: adım 1, 3 resimden 3.
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your MacBook Air and unplug all cables.
    • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
  2. MacBook Air 2022 (M2) Headphone Jack Replacement, Unfasten the lower case: adım 2, 2 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Unfasten the lower case: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
    • Two screws with a short threaded portion near the hinges
    • Two screws with a long threaded portion near the front of the MacBook
  3. MacBook Air 2022 (M2) Headphone Jack Replacement, Insert an opening pick: adım 3, 3 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Insert an opening pick: adım 3, 3 resimden 2. MacBook Air 2022 (M2) Headphone Jack Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Air 2022 (M2) Headphone Jack Replacement, Release the snapping clips: adım 4, 3 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Release the snapping clips: adım 4, 3 resimden 2. MacBook Air 2022 (M2) Headphone Jack Replacement, Release the snapping clips: adım 4, 3 resimden 3.
    • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next clip.
  5. MacBook Air 2022 (M2) Headphone Jack Replacement: adım 5, 3 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement: adım 5, 3 resimden 2. MacBook Air 2022 (M2) Headphone Jack Replacement: adım 5, 3 resimden 3.
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the two remaining snapping clips.
  6. MacBook Air 2022 (M2) Headphone Jack Replacement, Release the sliding tabs: adım 6, 3 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Release the sliding tabs: adım 6, 3 resimden 2. MacBook Air 2022 (M2) Headphone Jack Replacement, Release the sliding tabs: adım 6, 3 resimden 3.
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. MacBook Air 2022 (M2) Headphone Jack Replacement, Remove the lower case: adım 7, 3 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Remove the lower case: adım 7, 3 resimden 2. MacBook Air 2022 (M2) Headphone Jack Replacement, Remove the lower case: adım 7, 3 resimden 3.
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. MacBook Air 2022 (M2) Headphone Jack Replacement, Remove the battery connector cover: adım 8, 1 resimden 1.
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
  9. MacBook Air 2022 (M2) Headphone Jack Replacement: adım 9, 2 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement: adım 9, 2 resimden 2.
    • Remove the battery connector cover.
  10. MacBook Air 2022 (M2) Headphone Jack Replacement, Disconnect the battery: adım 10, 2 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Disconnect the battery: adım 10, 2 resimden 2.
    • Use an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. MacBook Air 2022 (M2) Headphone Jack Replacement, Unfasten the headphone jack connector cover: adım 11, 2 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Unfasten the headphone jack connector cover: adım 11, 2 resimden 2.
    • Use a T3 Torx screwdriver to remove the two 1.5 mm screws securing the headphone jack connector cover.
  12. MacBook Air 2022 (M2) Headphone Jack Replacement, Remove the headphone jack connector cover: adım 12, 2 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Remove the headphone jack connector cover: adım 12, 2 resimden 2.
    • Remove the headphone jack connector cover.
  13. MacBook Air 2022 (M2) Headphone Jack Replacement, Free the headphone jack: adım 13, 2 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Free the headphone jack: adım 13, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect lid angle sensor press connector.
  14. MacBook Air 2022 (M2) Headphone Jack Replacement: adım 14, 1 resimden 1.
    • Gently peel the lid angle sensor cable from the top of the headphone jack and move it out of the way.
  15. MacBook Air 2022 (M2) Headphone Jack Replacement: adım 15, 2 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement: adım 15, 2 resimden 2.
    • Disconnect the headphone jack press connector.
  16. MacBook Air 2022 (M2) Headphone Jack Replacement, Unfasten the headphone jack: adım 16, 2 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Unfasten the headphone jack: adım 16, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the two 4.8 mm screws securing the headphone jack.
  17. MacBook Air 2022 (M2) Headphone Jack Replacement, Remove the headphone jack: adım 17, 3 resimden 1. MacBook Air 2022 (M2) Headphone Jack Replacement, Remove the headphone jack: adım 17, 3 resimden 2. MacBook Air 2022 (M2) Headphone Jack Replacement, Remove the headphone jack: adım 17, 3 resimden 3.
    • Tilt the headphone jack towards the left edge of the laptop, dislodging it from its recess.
    • Lift the headphone jack straight up and remove it.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Spencer Day
96.225 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 31
Son 30 gün: 107
Her zaman: 2,009
