Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
Lift the memory cover up and out of the computer.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
Remove the following 3 screws from the rear wall of the battery compartment:
One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
Remove the following 4 screws from the back of the computer:
Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Remove the two Phillips screws from the optical drive (right) side of the computer:
Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Bu adımda kullanılan alet:Plastic Cards$2.99-
Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
Carefully peel up the black felt tape between the heat sink and fan.
Peel up the small black rubber cover from the right side of the heat sink.
Use a spudger to disconnect the two newly-revealed temperature sensor connectors from the logic board.
Remove the four Phillips screws securing the heat sink to the lower case.
Lift the heat sink out of the computer, making sure the black tape doesn't catch on the heat sink.
118 farklı kişi bu kılavuzu tamamladı.
7 Yorum
what if the black felt tape is dissolve itself in step 13? do i have to renew it or doesnt metter? it just crumbled.
Hi.
I love these guides, they have helped me to replace the airport card, replace the keyboard cable and modify the optibay to install a 2nd drive.
The last 2 jobs I have completed were to remove the cooling fan to clean it and the exit of the heat sink and later to remove the heat sink to renew the thermal paste conducting material.
My suggestions would be if you are going to remove the heat sink take out the cooling fan first. This is just because the removal of the heat sink is much easier if the fan is out and it's really not too much more work and when you re-assemble make sure the black tape is really sticking down, if it's not the full cooling will be lost and funnily enough the noise of the fan increases.
Thanks ifixit team, you have been life savers.
respect
I used the guide and had no problems getting to the point of replacing the heatsink. I see how the rear heat sensor (250) clips onto the logic board but for the life of me, I cannot see how the longer sensor attaches. I see two contacts but other than the felt thing, there is no way to attach. . . What did I do wrong. . . HELP. Milt King
To refit the temperature sensors, ensure the cables are rooted under the clips of the heatsink. The connectors then just push down on to the motherboard pins.
