Ana içeriğe geç
MacBook Core Duo Logic Board Replacement
Neye ihtiyacın var
    1. MacBook Core Duo Logic Board Replacement, Battery: adım 1, 1 resimden 1.
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core Duo Logic Board Replacement: adım 2, 1 resimden 1.
      • Lift the battery out of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Core Duo Logic Board Replacement, Memory Cover: adım 3, 1 resimden 1.
      • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover.
      • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core Duo Logic Board Replacement: adım 4, 1 resimden 1.
      • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Core Duo Logic Board Replacement, Upper Case: adım 5, 1 resimden 1.
      • Remove the following 3 screws:
      • One 11 mm Phillips #00 in the middle of the case.
      • Two 14.5 mm Phillips #00.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core Duo Logic Board Replacement: adım 6, 1 resimden 1.
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
      • One 4 mm Phillips #00 on the right side.
      • When reinstalling these screws, press gently on the lower case to line up the screw holes.
      • These screws easily strip, so be careful while taking these particular screws out.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Core Duo Logic Board Replacement: adım 7, 1 resimden 1.
      • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Core Duo Logic Board Replacement: adım 8, 1 resimden 1.
      • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
      FixBot'a Sor
      Yorum Ekle
    5. MacBook Core Duo Logic Board Replacement: adım 9, 1 resimden 1.
      • Remove the following 4 screws from the back of the computer:
      • Two 7 mm shouldered Phillips on the far sides.
      • Two 10.5 mm Phillips toward the center.
      • Do not over-tighten these; you can cause the case to distort.
      FixBot'a Sor
      Yorum Ekle
    6. MacBook Core Duo Logic Board Replacement: adım 10, 1 resimden 1.
      • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
      • It is not necessary to remove the similar screws on the other side of the computer.
      FixBot'a Sor
      Yorum Ekle
    7. MacBook Core Duo Logic Board Replacement: adım 11, 1 resimden 1.
      • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
      • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
      • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
      FixBot'a Sor
      Yorum Ekle
    8. MacBook Core Duo Logic Board Replacement: adım 12, 1 resimden 1.
      • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
      • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
      • Do not pry from the bottom or the top, but from the sides.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Core Duo Logic Board Replacement, Left I/O Frame: adım 13, 1 resimden 1.
      • Disconnect the MagSafe board cable from the logic board.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core Duo Logic Board Replacement: adım 14, 1 resimden 1.
      • Remove the single Phillips screw securing the left speaker to the lower case.
      • Lift the left speaker out of its housing and set it to the side.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Core Duo Logic Board Replacement: adım 15, 1 resimden 1.
      • Two 7.5 mm Phillips from either end of the left I/O frame.
      • One 9 mm Phillips from the middle of the left I/O frame.
      • Remove the small black plastic spacer at the bottom of the left I/O frame.
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Core Duo Logic Board Replacement: adım 16, 1 resimden 1.
      • Lift the left I/O frame up and out of the computer. Pay attention to the thin metal EMI fingers, as they may catch as you remove the left I/O frame.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Core Duo Logic Board Replacement, Logic Board: adım 17, 1 resimden 1.
      • Peel up the foil tape between the fan and the optical drive.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core Duo Logic Board Replacement: adım 18, 1 resimden 1.
      • Use a spudger to move the gray display data and black speaker cables to the right. This will reveal a silver screw securing the fan housing to the lower case.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Core Duo Logic Board Replacement: adım 19, 1 resimden 1.
      • Disconnect the orange optical drive ribbon cable from the logic board.
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Core Duo Logic Board Replacement: adım 20, 1 resimden 1.
      • Peel up the small black rubber cover from the right side of the heat sink.
      FixBot'a Sor
      Yorum Ekle
    5. MacBook Core Duo Logic Board Replacement: adım 21, 1 resimden 1.
      • Disconnect the black fan connector and two white temperature sensor connectors from the logic board.
      FixBot'a Sor
      Yorum Ekle
    6. MacBook Core Duo Logic Board Replacement: adım 22, 1 resimden 1.
      • Remove the following 6 screws:
      • One 3 mm Phillips on the right side of the fan.
      • One 6 mm Phillips on the left side of the fan.
      • Four 9 mm Phillips securing the heat sink to the lower case.
      FixBot'a Sor
      Yorum Ekle
    7. MacBook Core Duo Logic Board Replacement: adım 23, 1 resimden 1.
      • Hold the heat sink with one hand and the fan with your other hand, and lift the heat sink and fan assembly out of the computer. The fan is attached to the heat sink only with a strip of black felt tape, so be sure to remove both parts as a unit
      • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
      FixBot'a Sor
      Yorum Ekle
    8. MacBook Core Duo Logic Board Replacement: adım 24, 1 resimden 1.
      • Disconnect the two antenna cables from the Airport card, and the black inverter cable from the logic board.
      FixBot'a Sor
      Yorum Ekle
    9. MacBook Core Duo Logic Board Replacement: adım 25, 1 resimden 1.
      • Remove the following 2 screws from the Airport card:
      • One 3 mm Phillips from the left side.
      • One 8 mm Phillips from the right side.
      FixBot'a Sor
      Yorum Ekle
    10. MacBook Core Duo Logic Board Replacement: adım 26, 1 resimden 1.
      • Grasp the Airport card at its top and slide it toward the screen and out of the computer.
      FixBot'a Sor
      Yorum Ekle
    11. MacBook Core Duo Logic Board Replacement: adım 27, 1 resimden 1.
      • Use a spudger to disconnect the left speaker connector from the logic board.
      • Lift the left speaker out of the computer.
      FixBot'a Sor
      Yorum Ekle
    12. MacBook Core Duo Logic Board Replacement: adım 28, 1 resimden 1.
      • Disconnect the display data cable by pulling up on the black plastic pull-tab. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
      FixBot'a Sor
      Yorum Ekle
    13. MacBook Core Duo Logic Board Replacement: adım 29, 1 resimden 1.
      • Disconnect the newly-revealed hard drive cable from the logic board.
      FixBot'a Sor
      Yorum Ekle
    14. MacBook Core Duo Logic Board Replacement: adım 30, 1 resimden 1.
      • Use a spudger to disconnect the two speaker connectors from the logic board.
      FixBot'a Sor
      Yorum Ekle
    15. MacBook Core Duo Logic Board Replacement: adım 31, 1 resimden 1.
      • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
      FixBot'a Sor
      Yorum Ekle
    16. MacBook Core Duo Logic Board Replacement: adım 32, 1 resimden 1.
      • Deroute the silver microphone cable from the silver metal clip just above the right RAM slot.
      FixBot'a Sor
      Yorum Ekle
    17. MacBook Core Duo Logic Board Replacement: adım 33, 1 resimden 1.
      • Use a spudger to carefully pry the battery connector up and disconnect it from the logic board.
      FixBot'a Sor
      Yorum Ekle
    18. MacBook Core Duo Logic Board Replacement: adım 34, 1 resimden 1.
      • Remove the three 3 mm Phillips screws securing the logic board to the lower case.
      FixBot'a Sor
      Yorum Ekle
    19. MacBook Core Duo Logic Board Replacement: adım 35, 1 resimden 1.
      • Lift the logic board up from the right side, and slide it up and out of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Core Duo Logic Board Replacement, Logic Board: adım 36, 1 resimden 1.
      • Turn the logic board over.
      • Peel the PRAM battery up from its location on the logic board, removing tape as necessary.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core Duo Logic Board Replacement: adım 37, 1 resimden 1.
      • Disconnect the PRAM battery cable from the logic board. Pull the connector horizontally out of the socket with the two battery wires.
      • Remove the PRAM battery from the computer.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Core Duo Logic Board Replacement: adım 38, 1 resimden 1.
      • Pull back on the metal lever and slide the RAM chip out of the logic board.
      • Repeat this process for the other RAM chip if there are two RAM chips currently installed in your computer.
      FixBot'a Sor
      Yorum Ekle
Sonuç
82 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
635 adet Kılavuz yazıldı
2Kılavuz Yorumları
is it possible to swap macbook 1,1 logic board (32bit) to macbook 4,1 (64bit) logic board? both model numbers are A1181.
I have black macbook 1,1 eating dust in the closet, but I would like to revive it to use it as an interior/music play machine.
Unfortunately, as my black macbook 1,1 has only 32bit CPU, it won’t upgrade above Snow Leopard.
I’d like to at least be able to upgrade where iTunes with Apple music is enabled, which probably is iTunes 12.
Thank you
SHIM Jihyun - Yanıt Paylaş
So…. Damaged one of the temperature connections. But Got the pram out. How can I check if its working. First time I've stripped one down. The instructions were top class
John Morecroft - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 110
Her zaman: 225,641
