Ana içeriğe geç
MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    FixBot'a Sor
    Yorum Ekle
  2. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
    FixBot'a Sor
    Yorum Ekle
  3. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 3, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 3, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 3, 3 resimden 3.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
    FixBot'a Sor
    Yorum Ekle
  4. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement, Battery Connector: adım 4, 1 resimden 1.
    • Remove the plastic cover adhered to the battery contact board.
    FixBot'a Sor
    Yorum Ekle
  5. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 5, 1 resimden 1.
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
    FixBot'a Sor
    Yorum Ekle
  6. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 6, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 6, 2 resimden 2.
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    FixBot'a Sor
    Yorum Ekle
  7. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 7, 1 resimden 1.
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    FixBot'a Sor
    Yorum Ekle
  8. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 8, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 8, 2 resimden 2.
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
    FixBot'a Sor
    Yorum Ekle
  9. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement, Battery Contact Board: adım 9, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement, Battery Contact Board: adım 9, 2 resimden 2.
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
    FixBot'a Sor
    Yorum Ekle
  10. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement, Heat Sink Assembly: adım 10, 1 resimden 1.
    • Remove the following screws securing the heat sink to the logic board assembly:
    • One 2.4 mm Phillips #00 screw
    • One 3.4 mm T5 Torx screw
    • Four 2.7 mm T5 Torx screws
    FixBot'a Sor
    Yorum Ekle
  11. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 11, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement: adım 11, 2 resimden 2.
    • Lift and remove the heat sink up off the logic board assembly.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
    FixBot'a Sor
    Yorum Ekle
  12. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement, Right Fan Duct: adım 12, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement, Right Fan Duct: adım 12, 2 resimden 2.
    • Carefully remove the right fan duct from the edge of the heat sink.
    FixBot'a Sor
    Yorum Ekle
  13. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement, Left Fan Duct: adım 13, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement, Left Fan Duct: adım 13, 2 resimden 2.
    • Carefully remove the left fan duct from the edge of the heat sink.
    FixBot'a Sor
    Yorum Ekle
  14. MacBook Pro 13" Retina Display Early 2013 Heat Sink Replacement, Heat Sink: adım 14, 1 resimden 1.
    • Heat sink remains.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.670 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
27.603 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 60
Her zaman: 6,591
