Ana içeriğe geç
MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    FixBot'a Sor
    Yorum Ekle
  2. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
    FixBot'a Sor
    Yorum Ekle
  3. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 3, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 3, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 3, 3 resimden 3.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
    FixBot'a Sor
    Yorum Ekle
  4. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, Battery Connector: adım 4, 1 resimden 1.
    • Remove the plastic cover adhered to the battery contact board.
    FixBot'a Sor
    Yorum Ekle
  5. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 5, 1 resimden 1.
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
    FixBot'a Sor
    Yorum Ekle
  6. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 6, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 6, 2 resimden 2.
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    FixBot'a Sor
    Yorum Ekle
  7. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 7, 1 resimden 1.
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    FixBot'a Sor
    Yorum Ekle
  8. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 8, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 8, 2 resimden 2.
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
    FixBot'a Sor
    Yorum Ekle
  9. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, Battery Contact Board: adım 9, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, Battery Contact Board: adım 9, 2 resimden 2.
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
    FixBot'a Sor
    Yorum Ekle
  10. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, Heat Sink Assembly: adım 10, 1 resimden 1.
    • Remove the following screws securing the heat sink to the logic board assembly:
    • One 2.4 mm Phillips #00 screw
    • One 3.4 mm T5 Torx screw
    • Four 2.7 mm T5 Torx screws
    FixBot'a Sor
    Yorum Ekle
  11. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 11, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 11, 2 resimden 2.
    • Lift and remove the heat sink up off the logic board assembly.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
    FixBot'a Sor
    Yorum Ekle
  12. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, I/O Board Data Cable: adım 12, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, I/O Board Data Cable: adım 12, 2 resimden 2.
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
    FixBot'a Sor
    Yorum Ekle
  13. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 13, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 13, 2 resimden 2.
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  14. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 14, 1 resimden 1.
    • Lift and remove the I/O board data cable from the MacBook Pro.
    FixBot'a Sor
    Yorum Ekle
  15. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, Right Fan: adım 15, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, Right Fan: adım 15, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, Right Fan: adım 15, 3 resimden 3.
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the right fan ribbon cable straight out of its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  16. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 16, 1 resimden 1.
    • Remove the three 3.1 mm T5 Torx screws securing the right fan to the logic board assembly.
    FixBot'a Sor
    Yorum Ekle
  17. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 17, 1 resimden 1.
    • Lift and remove the right fan out of the upper case.
    FixBot'a Sor
    Yorum Ekle
  18. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, AirPort Board Assembly: adım 18, 1 resimden 1.
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
    FixBot'a Sor
    Yorum Ekle
  19. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 19, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 19, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 19, 3 resimden 3.
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
    FixBot'a Sor
    Yorum Ekle
  20. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 20, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 20, 2 resimden 2.
    • Move the antenna cables aside, clear of the AirPort board.
    FixBot'a Sor
    Yorum Ekle
  21. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 21, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 21, 2 resimden 2.
    • Pull the AirPort board straight out of its socket on the I/O board.
    FixBot'a Sor
    Yorum Ekle
  22. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, I/O Board: adım 22, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement, I/O Board: adım 22, 2 resimden 2.
    • Use the tip of a spudger to push the edges of the I/O board power connector straight out of its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
    FixBot'a Sor
    Yorum Ekle
  23. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 23, 1 resimden 1.
    • Pull the I/O board connector straight out of its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  24. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 24, 1 resimden 1.
    • Remove the following two screws securing the I/O board to the upper case:
    • One 3.5 mm T5 Torx screw
    • One 4.9 mm T8 Torx screw
    FixBot'a Sor
    Yorum Ekle
  25. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 25, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 I/O Board Replacement: adım 25, 2 resimden 2.
    • Carefully pull and remove the I/O board away from its recess in the upper case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.658 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
27.525 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 50
Her zaman: 5,219
