Giriş
Use this guide to replace the I/O board.
Neye ihtiyacın var
Bu adımda kullanılan alet:Magnetic Project Mat$16.96
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Bu adımda kullanılan alet:Tweezers$4.99
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Remove the following screws securing the heat sink to the logic board assembly:
One 2.4 mm Phillips #00 screw
One 3.4 mm T5 Torx screw
Four 2.7 mm T5 Torx screws
Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
Pull the right fan ribbon cable straight out of its socket on the logic board.
Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
Use the tip of a spudger to push the edges of the I/O board power connector straight out of its socket on the logic board.
6 farklı kişi bu kılavuzu tamamladı.
