Ana içeriğe geç
MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 3, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 3, 2 resimden 2.
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Battery Connector: adım 4, 1 resimden 1.
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 5, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 5, 2 resimden 2.
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 6, 1 resimden 1.
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Heat Sink: adım 7, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Heat Sink: adım 7, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Heat Sink: adım 7, 3 resimden 3.
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 8, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 9, 1 resimden 1.
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
  10. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 10, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 10, 2 resimden 2.
  11. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Fan: adım 11, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Fan: adım 11, 2 resimden 2.
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 12, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 12, 2 resimden 2.
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  13. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 13, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 13, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 13, 3 resimden 3.
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
  14. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 14, 1 resimden 1.
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
  15. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 15, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 15, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 15, 3 resimden 3.
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
  16. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Logic Board Assembly: adım 16, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Logic Board Assembly: adım 16, 2 resimden 2.
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
    • Remove the I/O board cable bracket.
  17. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 17, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 17, 2 resimden 2.
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  18. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 18, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 18, 2 resimden 2.
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  19. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 19, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 19, 2 resimden 2.
    • Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
  20. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 20, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 20, 2 resimden 2.
    • With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
  21. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 21, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 21, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 21, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
  22. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 22, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 22, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 22, 3 resimden 3.
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
  23. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 23, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 23, 2 resimden 2.
    • Carefully pull the DC-In board connector straight out of its socket on the logic board.
  24. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 24, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 24, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 24, 3 resimden 3.
    • Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
  25. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 25, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 25, 2 resimden 2.
    • If necessary, peel back any tape covering the microphone cable ZIF connector.
  26. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 26, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 26, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 26, 3 resimden 3.
    • Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
    • Pull the microphone cable out of its socket on the logic board.
  27. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 27, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 27, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 27, 3 resimden 3.
    • If necessary, peel back any tape covering the keyboard cable connector.
    • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
  28. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 28, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 28, 2 resimden 2.
    • Pull the keyboard cable straight out of its ZIF socket on the logic board.
  29. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 29, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 29, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 29, 3 resimden 3.
    • If necessary, peel back any tape covering the trackpad cable connector.
  30. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 30, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 30, 2 resimden 2.
    • Pull the trackpad ribbon cable straight out of its socket on the logic board.
  31. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 31, 1 resimden 1.
    • Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
    • When reassembling, install all five screws loosely, position the logic board, and then tighten evenly.
  32. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 32, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 32, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 32, 3 resimden 3.
    • Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
    • Remove the logic board.
    • When reinstalling, make sure the keyboard, keyboard backlight, MagSafe, and microphone cables don't get trapped beneath the logic board.
    • Also be sure to slide the ports' metal EMI fingers under the side of the case, not over.
  33. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Logic Board: adım 33, 1 resimden 1.
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  34. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 34, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 34, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: adım 34, 3 resimden 3.
    • Lift the free end of the SSD up slightly and pull it straight out of its socket on the logic board.
Sonuç
53 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
474.968 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.648 adet Kılavuz yazıldı
10Kılavuz Yorumları
Hi @sam !
I have a macbook pro 13" retina i5 2.6 8gb mid 2014 Model. A1502 and it has the damaged board.
In SAT, I changed it for 600 euros to replace it.
I have found a logicboard used for this same model A1502 (i7 3.0 Ghz 8Gb Ram) for half price and I would like to know if it is possible to replace it for this, or the mac will give me some problem when plugging a logicboard with different characteristics that the original?
Thanks for you support !
neotic82 - Yanıt
Was these ever answered?
Jimbo Hayze -
Question: Can I put a 2014 logic board in a 2015 model? I have a water damaged MF839LL/a 2015 model, but I can get a MGX72LL/a 2014 model logic board for cheap. Thanks!
Danny M - Yanıt
Sam, thank you so much! Repair guide worked perfectly for removing logic board to clean corrosion after a water spill on the keyboard! Everything was exactly as picture and explained. I have two questions I was hoping Sam or someone else knowledgeable could answer.
1. Can/ should I replace the foam stickers from the heat sink screws (step 8)? If so, what kind of computer safe adhesive should I use to ensure that they stay in place?
2. Should the plastic cover adhered to the battery contact board in step 4 be replaced?
Andrew Lingousky - Yanıt
Thanks from the bottom of my feet for the excellent guide, my water-damaged mac lives again! Everything works but the power button…
stupple82 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 399
Son 30 gün: 1,138
Her zaman: 88,516
