Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. MacBook Pro 13" Touch Bar 2018 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. MacBook Pro 13" Touch Bar 2018 Teardown, MacBook Pro 13" Touch Bar 2018 Teardown: adım 1, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown, MacBook Pro 13" Touch Bar 2018 Teardown: adım 1, 2 resimden 2.
    • Before we put this one under the knife, let's review what we exspec to find:
    • 13.3" LED-backlit IPS Retina display with True Tone, 2560 x 1600 resolution (227 dpi), P3 wide color gamut
    • 2.3 GHz quad-core Intel Core i5 (Turbo Boost up to 3.8 GHz) with integrated Intel Iris Plus Graphics 655
    • Apple T2 custom coprocessor
    • 8 GB of 2133 MHz LPDDR3 SDRAM
    • 256 GB PCIe-based SSD
    • 802.11ac Wi-Fi and Bluetooth 5.0
    • Four Thunderbolt 3 (USB-C) ports supporting charging, DisplayPort, Thunderbolt, USB 3.1 Gen 2
  2. MacBook Pro 13" Touch Bar 2018 Teardown: adım 2, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown: adım 2, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Teardown: adım 2, 3 resimden 3.
    • Spoiler alert! As always, we like to start off with a superhero's-eye-view of our victim's internals.
    • These X-ray images come to you thanks to our ingenious pals at Creative Electron.
    • Don't worry, we're still going to take it apart. Hold that thought ...
  3. MacBook Pro 13" Touch Bar 2018 Teardown: adım 3, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown: adım 3, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Teardown: adım 3, 3 resimden 3.
  4. MacBook Pro 13" Touch Bar 2018 Teardown: adım 4, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown: adım 4, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Teardown: adım 4, 3 resimden 3.
    • Our teardown begins in earnest—we dispatch a sextuplet of pentalobe screws, and dash through what by now is a pretty familiar opening procedure.
    • At first glance, the internals look very similar to the 13" MacBook Pro from last year ... and the year before that.
    • At second glance, we decide to go in closer for a third glance.
  5. MacBook Pro 13" Touch Bar 2018 Teardown: adım 5, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown: adım 5, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Teardown: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Marlin Screwdriver Set - 5 Specialty Precision Screwdrivers
    $22.99
    Satın Al
    • We disconnect the battery without any drama—it's buttoned down with a T5 Torx screw, so we use one of our blue and black Pro Tech specialty drivers to dispatch it.
    • At 58.0 Wh, this battery has gotten a significant boost over the 49.2 Wh unit we found in our original 13" Touch Bar teardown.
    • Turns out that extra 'oomph' comes from a slightly bigger battery—arrayed into six cells this time, instead of five. It's also heavier, weighing in at in at 232.7 g, versus the old battery's 196.7 g.
    • And yet this MacBook Pro's total weight hasn't changed one iota. We're not sure which parts of this device have been on a diet, but it does look like Apple shaved some mass off the top case.
    • Despite all that, Apple still rates battery life the same as the prior model. Those extra processor cores don't come for free.
    • The new-and-improved speakers (on the right) have grown, too—they're longer and narrower, filling all the remaining space, and bumping right up against the logic board thanks to the revised top case design.
  6. MacBook Pro 13" Touch Bar 2018 Teardown: adım 6, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown: adım 6, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Teardown: adım 6, 3 resimden 3.
    • In a lone piece of happy repair news: the trackpad is replaceable as ever. Twirl away a few Torx screws, and off it flies.
    • We get our first taste of some chips under the trackpad (looking virtually unchanged from their first outing back in 2016):
    • STMicroelectronics STM32F103VB ARM Cortex-M3 MCU
    • Broadcom BCM5976C1KUFBG Touch Controller
    • Maxim Integrated MAX11291ENX 24-Bit, 6-Channel Delta-Sigma ADC
    • Meanwhile, we can't help but notice the earlier model's port to nowhere—which turned out to be for data recovery—is mysteriously absent.
    • Given this MacBook's non-removable storage, Apple must have a new recovery method?
    • Update: They didn't—until they did.
  7. MacBook Pro 13" Touch Bar 2018 Teardown: adım 7, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown: adım 7, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Teardown: adım 7, 3 resimden 3.
    • Apple was careful to mention its latest third-gen keyboard in its press release. The added quietness seems a bit underwhelming to our ears, and we suspect there's something more going on.
    • After three years of key-cap removal, we're able to pop this lid open without damaging the delicate clips, and boy are we rewarded.
    • As you may have heard, there's a brand new silicone barrier under here.
    • Apple says this new addition is purely for soundproofing, but it bears a suspicious resemblance to their 2016 ingress-proofing patent—one that might help prevent the keyboard failures we keep hearing about.
    • This bears further analysis. We'll have a deeper dive on the keyboard situation later in the week. Stay tuned!
  8. MacBook Pro 13" Touch Bar 2018 Teardown: adım 8, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown: adım 8, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Teardown: adım 8, 3 resimden 3.
    • Time to liberate that logic board and look around!
    • As usual, a relatively modest-looking heat sink handles cooling for the CPU and integrated graphics. Another par for the course: Apple's typical glut of thermal paste.
    • And our first peep of silicon reveals: the touted T2!
    • Seen previously in the iMac Pro, Apple's custom T2 chip has taken over an impressive number of functions—but, we still expect to find a lot of other silicon on this board. Let's check it out!
  9. MacBook Pro 13" Touch Bar 2018 Teardown: adım 9, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown: adım 9, 2 resimden 2.
    • Here's a familiar mustache full of chips:
    • 8th-generation Intel Core i5-8259U CPU with Intel Iris Plus Graphics 655
    • Apple T2 APL1027 339S00533 coprocessor, layered over 1 GB Micron MT53B256M32D1TG-062 XT:C LPDDR4
    • Toshiba TSB 3226 J86404 TWNA1 (likely 2x 64 GB flash memory, 128 GB total on this side)
    • 4x SKhynix H9CCNNNBJTALAR-NVD 16 Gb LPDDR3 2133 MHz (8 GB total)
    • Intel JHL7540 Thunderbolt 3 Controller
    • Apple/Universal Scientific Industrial (USI) 339S00428 Wi-Fi/Bluetooth module
    • 338S00267-A0 (likely Apple PMIC)
  10. MacBook Pro 13" Touch Bar 2018 Teardown: adım 10, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown: adım 10, 2 resimden 2.
    • And we flip it around for some bonus silicon:
    • 2x Toshiba TSB 3226 J86404 TWNA1 64 GB flash memory, for 128 GB on this side and 256 GB total)
    • 2x Texas Instruments CD3215C00 83CFZST
    • Cirrus Logic CS42L83A Audio Codec
    • Intersil ISL95828AHRTZ PWM controller
    • 2x NXP Semiconductor CBTL06142F display port multiplexer
    • Texas Instruments TPS51980A synchronous buck controller
    • NXP Semiconductor PN80V secure NFC module
  11. MacBook Pro 13" Touch Bar 2018 Teardown: adım 11, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown: adım 11, 2 resimden 2.
    • IC Identifications, continued:
    • ON Semiconductor FDMF5808A, FDMF5804, and Vishay SIC532 power stage
    • Apple 338S00438 ? power management
    • Bosch Sensortec BMA282 accelerometer and Texas Instruments TMP464 5-Ch. remote/local temperature sensor
    • Diodes Incorporated PI3USB32 dual SPST USB 2.0 switch
    • Winbond W25Q80DV 8 Mb serial NOR flash memory
    • Texas Instruments TASxxxx audio amplifier
    • Texas Instruments TPS51916 DDR memory power management
  12. MacBook Pro 13" Touch Bar 2018 Teardown: adım 12, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Teardown: adım 12, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Teardown: adım 12, 3 resimden 3.
    • And for our dessert course we have: a brand new USB-C power adapter!
    • The A/C adapter included with this 13" MacBook Pro does indeed sport the new model number A1947 (vs. A1718, bottom), so it's time to bust out the ultrasonic cutter and go to town.
    • After clawing painfully through more layers and rubberized filler than we've ever seen in one of these things, we finally free the internals.
    • Opening the previous adapter (on the left) was a walk in the park compared to this unit, but it does look like this model benefits from redesigned internals, some additional shielding, and lots of impact-resistant foam rubber.
    • That said, Apple has also swapped the aluminum USB-C port for a plastic one ...
  13. MacBook Pro 13" Touch Bar 2018 Teardown: adım 13, 1 resimden 1.
    • Here's what's left after the 2018 MacBook Pro gave up its secrets, including:
    • A bigger battery that squeezed the speakers into a narrower form factor.
    • A keyboard decked out with a thin silicone barrier, which could be for sound baffling, but matches Apple ingress-proofing patents.
    • And a seemingly unchanged thermal management system, despite the extra power under the hood.
    • Teardown Update: we wanted to drill a bit deeper into the new keyboard, so we did some testing and then gave it another teardown all to itself. Check it out!
    • And if we missed something, check out our teardowns of the 2016 and 2017 models—you may well find it there!
  14. Son Düşünceler
    • The trackpad can be removed without first removing the battery.
    • The processor, RAM, and flash memory are soldered to the logic board. Repairs and upgrades will be impractical at best.
    • The top case assembly, which includes the keyboard, battery, and speakers, is glued together—making all those components impractical to replace separately.
    • The Touch ID sensor doubles as the power switch, and is paired with the T2 chip on the logic board. Fixing a broken power switch may require help from Apple, or a new logic board.
    Onarılabilirlik Puanı
    Onarılabilirlik 10 üzerinden 1
    (10 en kolay onarılabileni)
Adam O'Camb
196.653 İtibar
416 adet Kılavuz yazıldı
53 Yorum
RAID 0 SSD? From Samsung?
Peter Gamble - Yanıt
Hi Peter,
The “SSD”/flash memory is made by Toshiba.
Arthur Shi -
Not in this series.
Keep in mind the T2 is a flash controller, so Apple is side stepping the PCIe/NVMe issue of the SSD instead using raw flash chips which are interleaved simular to how memory is done. The T2 presents the PCIe/NVMe interface to rest of the system.
In truth it’s like RAID, but it’s not! It’s something newer! As it’s soldered to the logic board Apple can get away with this.
Dan -
To elaborate on what Dan said, the T2 chip includes Apple’s own NVMe PCIe SSD controller, which they developed in house. Like most SSD controllers, it uses multiple channels (maybe 8 in this case?) to address the NAND flash dies and increase performance through parallelism. Both the T2 and the NAND flash packages are soldered directly to the logic board. It is also likely that the drive can tolerate the failure of individual blocks and pages, or perhaps even whole NAND dies by using parity data.
This is a different concept than RAID though, which employs Redundant Arrays of Independent Drives to increase availability and in some cases performance. RAID 0 in particular ditches the redundant bit and stripes across an array of independent drives purely for increased performance. Apple decided to put the NAND flash packages for the iMac Pro on a pair of removable modules, however they were in no way independent drives. There was still only a single SSD controller located in the T2 chip on the logic board.
repoman27 -
The T2 processor should not be NAND Flash controller here. T2 is more like a RAID controller. Refer to https://duo.com/blog/apple-imac-pro-and-... The Toshiba chip here could be a PCIe/NVMe SSD in BGA chip package(like the one in the iPhone/iPad). The physical interface between T2 and Toshiba chip could be PCIe interface. T2 processor is also used to replace TI’s SMC controller.
JJ Wu -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 40
Son 7 gün: 238
Son 30 gün: 1,165
Her zaman: 335,480
