Ana içeriğe geç
MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement
  1. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, RAM Shield: adım 2, 1 resimden 1.
    • Remove the three identical Phillips screws from the memory door.
  3. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 3, 1 resimden 1.
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, Upper Case: adım 4, 1 resimden 1.
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  5. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 5, 1 resimden 1.
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 6, 1 resimden 1.
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 7, 1 resimden 1.
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 8, 1 resimden 1.
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 9, 1 resimden 1.
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
  10. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 10, 1 resimden 1.
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, Optical Drive: adım 11, 1 resimden 1.
    • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
  12. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 12, 1 resimden 1.
    • Remove the following 4 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.7 mm silver T6 Torx screw from the top left corner of the drive
    • One 6.2 mm black Phillips screw at the top right corner of the drive.
  13. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 13, 1 resimden 1.
    • Lift the optical drive up and out of the computer.
  14. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, Logic Board: adım 14, 1 resimden 1.
    • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  15. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 15, 1 resimden 1.
    • Disconnect the iSight and display data cables from the logic board by sliding the cables out of their connectors, removing tape as necessary.
  16. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 16, 1 resimden 1.
    • Disconnect the eight indicated connectors by placing a spudger beneath each cable and lifting up.
  17. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 17, 1 resimden 1.
    • Remove the silver T6 Torx screw securing the ground loop in the display data cable to the casing.
  18. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 18, 1 resimden 1.
    • Remove the single T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
    • Lift the clear plastic shield off the right ambient light sensor.
  19. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 19, 1 resimden 1.
    • Peel up the orange Kapton tape securing the right thermal sensor cable to the logic board.
  20. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 20, 1 resimden 1.
    • Remove the following 15 screws:
    • One 4.4 mm black Phillips screw to the right of the ram slot.
    • Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
    • One 6.2 mm black T6 Torx screw on the right side of the left fan.
    • Five 9.4 mm silver T6 Torx screws securing the left and right fans.
  21. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 21, 1 resimden 1.
    • Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
    • Place the fan above the Airport card. It is not necessary to remove the fan from the computer entirely.
  22. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 22, 1 resimden 1.
    • Lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
    • Remove the right fan from the computer.
  23. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 23, 1 resimden 1.
    • Lift up the left side of the logic board and disconnect the gray and black power cable from the bottom of the board.
  24. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 24, 1 resimden 1.
    • Grasp the logic board at the left side and at the thin section, and rotate the logic board out of the lower case.
    • To properly reassemble your MacBook Pro, you'll have to clean off and replace the old thermal compound. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
  25. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement, Speakers: adım 25, 1 resimden 1.
    • Lift the heat sink out of the computer.
  26. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 26, 1 resimden 1.
    • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
    • Remove the left fan from the computer.
  27. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 27, 1 resimden 1.
    • Disconnect the three antenna cables attached to the Airport Extreme card.
    • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
  28. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 28, 1 resimden 1.
    • Deroute the Airport antenna cables from their channel in the left speaker.
  29. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 29, 1 resimden 1.
    • Remove the single black T6 Torx screw located just above the Airport Extreme card.
    • Lift the small silver metal retaining bracket up and out of the computer.
  30. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 30, 1 resimden 1.
    • Lift the Airport Extreme card up and slide it out of its connector.
  31. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 31, 1 resimden 1.
    • Peel up the orange hard drive cable from above the ExpressCard cage.
  32. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 32, 1 resimden 1.
    • Disconnect the speaker cable from the corner of the left I/O board.
  33. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 33, 1 resimden 1.
    • Carefully peel up the black adhesive tape securing the speaker cable along the rear edge of the lower case.
  34. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 34, 1 resimden 1.
    • Continue to free the speaker cable from the black tape until it is free from all three sections of tape.
  35. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 35, 1 resimden 1.
    • Remove the single black T6 Torx screw securing the right speaker to the lower case.
  36. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 36, 1 resimden 1.
    • Use a spudger to pry up the right speaker from the lower case.
    • Remove the speakers from the computer.
  37. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 37, 1 resimden 1.
    • Remove the single silver Phillips screw securing the clear plastic shield over the left ambient light sensor.
    • Lift the clear plastic shield off the left ambient light sensor.
  38. MacBook Pro 15" Core 2 Duo Model A1211 Speakers Replacement: adım 38, 1 resimden 1.
    • Use a spudger to pry the left ambient light sensor board out of its housing on the left speaker.
    • Speakers remain.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 12,041
