Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If your MagSafe 2 power adapter has been damaged, you can replace it. Use this guide to install a replacement MagSafe DC-In Board.
Neye ihtiyacın var
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
Remove the I/O Board cable from the MacBook Pro.
Remove the single 2.9 mm T5 Torx screw securing the AirPort card to the logic board.
Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
Use the flat end of a spudger to pry the headphone jack connector up from its socket on the logic board.
Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
Clockwise from top: keyboard, trackpad, battery, right speaker, keyboard backlight, display, microphone, headphone jack, left speaker.
Remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
Slide the MagSafe DC-In board towards the right free it from its recess within the upper case.
Lift and remove the MagSafe DC-In board out of the upper case assembly.
27 farklı kişi bu kılavuzu tamamladı.
9 Yorum
What are some cases in which a magsafe board might be damaged and require replacement?
Magsafe connectors seem to arc a little bit when connected/disconnected. Over time, they degrade and eventually can need replacing.
Unbelievable how little thought is put into the replacement of parts that are likely to fail in these machines.
Awesome guide, thanks! My magsafe connector started getting very hot when charging and eventually stopped working entirely.
Full functionality restored. One thing that needs a better explanation is how the hinged ZIF connectors are opened, such as that for the keyboard.
i broke all of the speaker hinges on the motherboard any fix around this ?
