Ana içeriğe geç
MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement
Neye ihtiyacın var
  1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, Access Door: adım 1, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, Access Door: adım 1, 2 resimden 2.
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
    The A1286 has no Access Door.!!
    I actually can see no sign of the battery!...
    aguib - Yanıt
    aguib kullanıcısından alıntı:
    I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
    lgc90 - Yanıt
    when will there be a guide for the other unibody macbook pro. that does not have an access door?
    irishking - Yanıt
    Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
    Max
    Max - Yanıt
    On other guides you state the height of the HD that can be supported, e.g. MacBook Pro 15" Core 2 Duo Model A1211 Hard Drive Replacement , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
    Can you confirm this?
    Many thanks in advance.
    ahothabeth - Yanıt
    SHerwood Ball kullanıcısından alıntı:
    My display and aluminum casing has separated.
    I don't know if it just snaps back together or does it need to be glued.
    I dropped mine on the carpeted stairs and the display still works.
    I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
    portion have been broken........
    SHerwood Ball - Yanıt
    When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
    thvv - Yanıt
    We always use left and right in reference to the computer when you're using it.
    Andrew Optimus Goldheart -
    Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
    I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
    The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
    Thanks for the directions ...could not have done it with out them!!!
    landryd - Yanıt
    Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
    jegonzalez80 - Yanıt
    Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
    kenneth krabat - Yanıt
  2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 2, 1 resimden 1.
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, Battery: adım 3, 1 resimden 1.
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
    • If the latch is depressed it will lock the battery in place.
    Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
    Kaila Potts - Yanıt
    No. You do not need to charge it completely before removing it.
    Titus (#1579) - Yanıt
  4. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, Lower Case: adım 4, 1 resimden 1.
    • Remove the following eight screws securing the lower case to the chassis:
    • One 5.4 mm Phillips screw.
    • Three 14 mm Phillips screws.
    • Four 3.5 mm Phillips screws.
    Hi, My name is Jess I need help asap I accidentally dropped my macbook Pro and i cant find the silver screw for the top left back side, Does any one know if I can replace it with an eye glass screw?? If you can help at all Please e-mail me at Chambliss_jess@yahoo.com thx please help me my bf is going off... ;(
    Jess - Yanıt
    The fixit PH00 is the wrong screw driver for this entire job. It did not fit in the screws, it was too pointy and caused screws to be rounded off.
    mattrittgers - Yanıt
  5. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 5, 1 resimden 1.
    • Using both hands, lift and remove the lower case off the upper case.
    About midway along each edge is a snap. To release each snap, gently slide the flat edge of a Spudger under the lower case, then lift the lower case away.
    jonathansturges - Yanıt
  6. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, Display Assembly: adım 6, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, Display Assembly: adım 6, 2 resimden 2.
    • If necessary, peel the EMI gasket off the camera cable connector.
    • Disconnect the camera cable by pulling the male end straight away from its socket toward the optical drive opening.
    • Do not try to lift this connector straight up off the board. Pull the connector parallel to the face of the logic board.
    • Deroute the camera data cable from the channel in the optical drive.
    I have a problem with previous made unprofessional teardown of this mac, and the port that the camera cable is connected to, on the m-board, is cracked, because somebody pulled it straight up .. can someone please, share an idea about the way of fixing it, or maybe a name of the part i need ?
    sanchoser - Yanıt
  7. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 7, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 7, 2 resimden 2.
    • Remove the two Phillips screws securing the camera cable bracket to the upper case.
    • The leftmost screw may remain captive in the camera cable.
    • Seperate the camera cable bracket from the camera cable and remove it from the computer.
    For reassembly, it would improve the instructions to note the exact orientation of the camera cable, as well as the LVDS cable, in these steps (7-10). This avoids confusion as to where those cables go when the display is reattached (working steps 11-13 in reverse).
    As viewed from the orientation of the laptop at this point (looking into the motherboard from the underside), these cables are routed ABOVE the mounting plates for the hinges.
    Viewed from the front of the machine (as it would be sitting on the desk in front of you during normal use), they are routed BELOW those plates.
    Haitham - Yanıt
    On the 13” there’s an additional screw securing the camera cable bracket to the speaker chamber thing. You have to then gently lift up on the speaker chamber corner.
    dgdeckert - Yanıt
  8. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 8, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 8, 2 resimden 2.
    • Grab the plastic pull tab secured to the LVDS cable lock and rotate it toward the DC-in side of the computer.
    • Pull the LVDS connector straight away from its socket.
    • When disconnecting the LVDS cable, do not pull on the black tab secured to the LVDS cable lock. We recommend wiggling the cable while applying tension to slowly "walk" the connector out of its socket.
  9. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 9, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 9, 2 resimden 2.
    • Remove the 7 mm Phillips screw from the LVDS cable bracket.
    • This screw may remain captive in the LVDS cable.
    • Lift the LVDS cable bracket out of the upper case.
    On the 13” there are TWO screws securing the LVDS cable bracket, of different lengths.
    dgdeckert - Yanıt
  10. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 10, 1 resimden 1.
    • Remove the two outer 6 mm Torx screws securing each side of the display to the upper case (four screws total).
    Ccouldn't make it past step 10 as the two T6 screws on the right stripped. I was using the correct tool, correctly seated, but the screws were simply unwilling to turn and the screw head gave out before they turned at all. The ones on the left came out alright, but there seems to be some type of thread glue on them. Recommendations on how to break that seal without stripping the screw heads might be a good idea. Otherwise - be forewarned.
    Jonathan Field - Yanıt
    I have the same problem with step 10. Can't remove the screw on the left, it is all damaged.
    Benny Chew - Yanıt
  11. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 11, 1 resimden 1.
    • Open your MacBook Pro so the display is perpendicular to the upper case.
    • Place your opened MacBook Pro on a table as pictured.
    • While holding the display and upper case together with your other hand, remove the 6 mm Torx screw from the lower display bracket.
    Unlock without removing them , the two remaining center 6mm Torx screws securing the display to the upper case.
    thierry28722 - Yanıt
  12. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 12, 1 resimden 1.
    • Be sure to hold the display and upper case together with your other hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining 6 mm Torx screw securing the display to the upper case.
    One of the Torx screws holding the Display in place failed to come out. I tried too hard and it shredded the head of the screw so there was no physical leverage to the screw driver, so I left it to avoid any further damage.
    So instead I removed ‘not’the torx screw on the computer but the one on the display itself. There are three on the inner part of the screen, two facing the display and the third on the other side. It sled out easily.
    It only added a couple of minutes to my time removing it.
    But a word of caution, you must remove the long plastic housing that holds the cables for the iSight and display, just be gentle and slide it off trying not to snag the cables, it should come off easy.
    cngdoon - Yanıt
  13. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 13, 3 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 13, 3 resimden 2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 13, 3 resimden 3.
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display away from the upper case, minding any brackets or cables that may get caught.
    If I purchase a MBP 15' for parts that has a good top case, LCD and Glass, could I stop at Step 14, replace the entire top case and reverse from Step 13 to put it back together? Or do I need to proceed with steps 14 to 21, loosening the glue, lifting the glass, replacing the LCD?
    jbarrick1 - Yanıt
    I think you should be good up to just Step 14 if that's the case.
    craig - Yanıt
    On the 13” just slightly open the display/lid a little more and it’ll fall away without needing to do any of the push forward/away stuff as depicted on the 15” here.
    dgdeckert - Yanıt
  14. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, Front Display Glass: adım 14, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, Front Display Glass: adım 14, 2 resimden 2.
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
    • Before starting, be sure to clean the display glass with lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier
    • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
    • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
    • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
    Another caution is needed - the heat gun is capable of discoloring the LCD panel (giving uneven coloration) if it overheats. This is possible on the low setting. Proceed cautiously, heating in increments until the glass releases.
    Alden Stradling - Yanıt
    I was wondering the same, is absolutely necessary to disassemble the screen to change the glass? Can I jump to step 21?
    caholzmann - Yanıt
    To change just the glass I used a hair dryer it gives off enough heat to do the job. Stand the computer up on its cover with the key board standing up.start at a corner heat the adhesive as you go along. I Put credit cards in as I went along so the adhesive doesn't stick again. take your time . Its easy.
    Robert Lachman - Yanıt
  15. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 15, 3 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 15, 3 resimden 2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 15, 3 resimden 3.
    Bu adımda kullanılan alet:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Satın Al
    • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
    • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • Slowly and gently pull the corner of the display glass up off the display assembly.
    • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
    Sufficiently heated is a meaningless phrase here. Is it two minutes? Three? Fifteen? An hour? I have tried doing this for increasing amounts of time while avoiding doing damage to the machine, and nothing is working. Sufficient heating needs definition.
    Keith McComb - Yanıt
    Hi Keith, the key here is that you want to warm the adhesive that's spread thoroughly behind the masked-black area of the glass around the screen to release, but not put enough heat at the rubber gasket that seals the closed top lid to the base. Too much heat, too soon, will deform the rubber. Too much and you'll never get the glass to release. The 2x that I have done this, however, even with sufficient (and significant) heat, I remember the glass taking a surprising amount of leverage to pull clear. A tactic: using your heat gun warm all the sides of the display from the front, in a circulating/racetrack fashion - about 20 rpm. After 30sec, focus on the left and top sides, seesawing from bottom left, to top left, to top right, and back. Do that at the same pace, about 5-10 passes. Then spend about 10 sec waving over the whole top left corner. That should get enough heat to enough places to help the glass separate to start placing picks, and you can continue to heat the margins as you progress.
    johnkimmel - Yanıt
  16. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 16, 3 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 16, 3 resimden 2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 16, 3 resimden 3.
    • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
    • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
    • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
    Be careful with the spudger and the soft rubber strip around the glass. Since the rubber strip has been heated up by the heat gun, it is easily smushed and deformed by the spudger.
    Rob - Yanıt
    Be patient and work slowly or else you will crack the glass like me.
    BillyRachel1 - Yanıt
    I can not get the glass to come up despite two tries and dicsoloring the LCD with too much heat. Why can't I get the glass to budge at all?
    bollucks66 - Yanıt
    It is better , instead of using the suction cup , to use small flat end spudger . The suction cup should be used first to detach the window from the gasket , not furthermore as it may brake the glass.
    Thierry de Montblanc - Yanıt
    I didn’t have large suction cups and the small ones didn’t work for me. Instead, I used an opening tool to pry up the glass slightly and got a guitar pick under it. Then I slowly worked the pick around the top three sides of the glass, heating sections of glue as I went.
    Daniel Arnfield - Yanıt
    I’ve managed to do it using hair dryer on max. First corner was though and took a lot of time to lift it. I decided to heat not only a corner but whole length and then it came off. I’ve put so much heat that was afraid I’ve damaged LCD, but it works fine. As BillyRachel1 said: patience is the way. In order to assemble it back I used old glue heated again. It’s easy but takes time.
    Note: Don’t do this at home if you have cats otherwise you going to spend next hour or so trying to remove their fur from between glass and LCD. It’s because they all levitate after using hot air and just wait to stick to the screen again.
    To be honest hardest thing was replacing clutch cover, took me so much time and I eventually cracked it.
    D. K. Labudek - Yanıt
  17. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 17, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 17, 2 resimden 2.
    • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
    • Attach a suction cup along the right side of the front glass panel.
    • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
    • Continue working along the right edge of the front display glass until it is separated from the display.
    • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
    If you don't have a guitar pick, playing cards works too.
    Rob - Yanıt
    I used old credit cards
  18. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 18, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 18, 2 resimden 2.
    • Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
    • Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
    • Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
  19. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 19, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 19, 2 resimden 2.
    • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
    • Attach a suction cup near the upper left corner of the glass display panel.
    • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
    • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
  20. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 20, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 20, 2 resimden 2.
    • Use a heat gun to soften the adhesive under the black strip along the left side of the front glass panel.
    • Attach a suction cup along the left side of the front glass panel.
    • Continue working along the left edge of the front display glass until it is separated from the display.
  21. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 21, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 21, 2 resimden 2.
    • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
    • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
    • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on.
    If you will be reusing the glass, with new adhesive, then you will want to remove the old adhesive. This is a bit of a pain, as alcohol doesn't work, and you need to be careful to avoid damaging the black screen border, which is black paint on the back (adhesive) side of the glass.
    To remove the adhesive, note that it is actually a thin film with rubber cement on both sides. First, use a razor to carefully pull up one corner of the film and gently peel it off of the glass. If you are gentle and slow, the underlying adhesive may also come off; if not, then rubbing with your finger or a hard rubber eraser will do the trick.
    griscom - Yanıt
    what to do when new glass starts to peel after a week ?
    labig - Yanıt
    If this is a rubber cement based glue, then would rubber solvent / thinner like N-Heptane help the removal process without damaging the black paint ?
    Sandman619 - Yanıt
    Don’t remove glue. Just reuse it by heating and sticking it again.
  22. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 22, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 22, 2 resimden 2.
    • Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
    • Do not forget to stick the camera bracket down to the new front display glass before reassembly.
    This step is only needed if replacing the glass. If you are only replacing the LCD, there is no need to do this step
    Rob - Yanıt
  23. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 23, 3 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 23, 3 resimden 2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 23, 3 resimden 3.
    • During the glass removal process, the camera cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your camera cable is still connected to the camera board, skip this step.
    • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
    • Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
    • Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
    • Reapply the piece of tape covering the camera cable socket.
  24. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, LCD: adım 24, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, LCD: adım 24, 2 resimden 2.
    • Slide the clutch cover toward the right edge of the display.
    • The clutch cover will move approximately .25" and stop. Do not force it too far to the right.
    • When reinstalling the clutch cover, be sure to slip it over the components protruding from the lower edge of the display about .25" to the right of its final installed position on the display.
    Do you necessarily need to remove the glass before you can remove the clutch cover?
    aye oh - Yanıt
  25. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 25, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 25, 2 resimden 2.
    • Starting at its far left end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
    • Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
    • Lift the clutch cover up off the front bezel and set it aside.
    • When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
  26. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 26, 1 resimden 1.
    • Remove the six 2.9 mm Phillips screws securing the LCD panel to the front bezel.
    Hey guys, I need to get the part where the screws are on, whats its name or where could I find it? That part on my Computer broke.... Do you guys think its possible to guet it somewhere?
    diegoantegr31 - Yanıt
  27. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 27, 1 resimden 1.
    • Pull the LCD toward the top edge of the display to slide the circuitry along its lower edge out of the recess in the aluminum display assembly.
    • It may be helpful to use one hand to feed the display data cable through its channel in the aluminum display assembly as you pull the LCD toward the top edge of the display with the other hand.
  28. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 28, 1 resimden 1.
    • Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
  29. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 29, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 29, 2 resimden 2.
    • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
    • Pull the display data cable straight away from its socket on the LCD.
    • Lift the LCD out of the display assembly and set it aside.
    • If you are replacing the LVDS/display data cable, simply de-route it from its slot cut into the display casing.
    Danke für das Bereitstellen der Anleitung dadurch konnte ich mein MacBook nach 12 Jahren Einsatz, für die nächsten Jahre fit machen.
    Thanks you for providing this Manuel. It helped me, after 12 year of use to make my MacBook fit for the coming years.
    Albert Zweistein - Yanıt
  30. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, Display Data Cable: adım 30, 2 resimden 1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement, Display Data Cable: adım 30, 2 resimden 2.
    • Carefully pull the display data cable through the recess located near the left hinge.
    • Do not use excessive force to pull the cable through as it may damage the connector.
  31. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement: adım 31, 1 resimden 1.
    • Display data cable remains.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
2 Yorum
How do you glue the LCD back?
javy105 - Yanıt
What time of glue should I use to glue the LCD back...
Thanks
turgeonj -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 27
Her zaman: 14,237
