Giriş
Upgrade your hard drive for more storage space.
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Remove the two 5-Point Pentalobe screws along the top edge of the battery.
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Lift the the retaining bracket out of the upper case.
Remove two T6 Torx screws from each side of the hard drive (four screws total).
205 farklı kişi bu kılavuzu tamamladı.
12 Comments
Piece of cake! Didn't have the 5-point, so I left the battery alone. Finder says I have 550G of free space!
Very Easy. Don't need to remove the battery.
Hi. Does myy macBook Pro (15" Mid 2009) support Solid State Drive? I upgraded the memory with 8 gigabites, but it´s still a bit slow. I hope someone can answer soon.
Yes you can. Look up crucial.com
kris -
