Ana içeriğe geç
MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement
Neye ihtiyacın var
  1. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement, Lower Case: adım 1, 1 resimden 1.
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 2, 1 resimden 1.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
    • Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
    • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
  4. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 4, 1 resimden 1.
    • Use the tip of your finger to carefully peel back the corner of the warning label to reveal a hidden Tri-point screw.
    • Remove the last 7.4 mm Tri-point screw securing the battery to the upper case.
  5. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 5, 2 resimden 1. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 5, 2 resimden 2.
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  6. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 6, 1 resimden 1.
    • Tilt the battery away from the logic board enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • Pull the battery cable connector away from the center of the logic board.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  7. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement, Hard Drive: adım 7, 1 resimden 1.
    • Remove two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  8. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 8, 1 resimden 1.
    • Lift the the retaining bracket out of the upper case.
  9. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 9, 1 resimden 1.
    • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
  10. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 10, 2 resimden 1. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 10, 2 resimden 2.
    • Remove the hard drive cable by pulling its connector straight away from the hard drive.
  11. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement, Hard Drive/IR Sensor Cable: adım 11, 1 resimden 1.
    • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
  12. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 12, 1 resimden 1.
    • Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
    • Two 1.5 mm Phillips screws.
    • Two 4 mm Phillips screws.
  13. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 13, 2 resimden 1. MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement: adım 13, 2 resimden 2.
    • Slide the hard drive and IR sensor bracket away from the edge of the upper case.
    • Carefully peel the hard drive and IR sensor cable from the upper case.
    • Lift the hard drive and IR sensor assembly out of the upper case.
Sonuç
36 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I followed with success this guide to fix my computer, thanks to an ifixit spare part ! Unfortunately I found very difficult to plug the hard drive IR cable to the IR sensor itself : for now it remained unplugged. Any tips regarding this point ? Thanks again.
auronil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 17
Son 30 gün: 44
Her zaman: 32,679
