Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace a broken left speaker. Replacing the left speaker requires removal of the logic board.
Neye ihtiyacın var
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
Tilt the battery away from the logic board enough to access the battery cable connector.
Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
Remove the three T6 Torx screws securing the right fan to the upper case.
13 farklı kişi bu kılavuzu tamamladı.
2 Yorum
I changed the left speaker with another one got on ebay. but still it has refused to work. what other methods can i try?
Stellar guide, easier than it looks at first, new left speaker from China, perfect sound once again in this 11-year old MBP.
