Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
The access door should now be raised enough to lift it up and out of the Unibody.
Grab the white plastic tab and pull the battery up and out of the Unibody.
Remove the following eight screws securing the lower case to the chassis:
One 3 mm Phillips screw.
Three 13.5 mm Phillips screws.
Four 3.5 mm Phillips screws.
Using both hands, lift and remove the lower case off the upper case.
Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
Use a spudger to pry the fan connector straight up off the logic board.
Remove the following three screws securing the fan to the upper case:
Two 5 mm Phillips screws.
One 7 mm Phillips screw.
Each connector is different, so the following steps will show you how disconnect each in detail.
Remove the single Phillips screw securing the battery cable cover to the upper case.
Remove the battery cable cover from the upper case.
Use a spudger to pry the battery level indicator cable connector straight up off the logic board.
Disconnect the battery cable connector by pulling it straight away from the logic board.
Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
Pull the keyboard ribbon cable straight out of its socket.
If the smaller connector at the right side of the keyboard ribbon cable is populated by another small black ribbon cable, remove it in a similar way to the above.
Use the flat end of a spudger to pry the trackpad connector straight up off the logic board.
Use the tip of a spudger to flip up the locking lever to release the IR sensor ribbon cable from its socket.
Use the tip of a spudger to pull the IR sensor ribbon cable straight away from the logic board.
Use the flat end of a spudger to pry the hard drive cable connector straight up off the logic board.
Use the flat end of a spudger to pry the optical drive cable connector straight up off the logic board.
Disconnect the display data cable by pulling the male end straight away from its socket.
Use the flat end of a spudger to pry the subwoofer cable connector straight up off the logic board.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
Pull the display data cable connector straight away from its socket.
Remove the following two screws securing the display data cable bracket to the upper case:
One 7mm Phillips screw.
One 5mm Phillips screw.
Remove the two 7 mm Phillips screws from the DC-in board.
Lift the display data cable bracket out of the upper case.
If present, remove the two 4mm Phillips screws securing the bottom case clip to the upper case.
Lift the bottom case clip out of the upper case.
Remove the two 5mm Phillips screws securing the keyboard flex bracket to the upper case.
Lift the keyboard flex bracket out of the upper case.
Use the tip of a spudger to release the microphone from the upper case.
Remove the following five screws securing the logic board to the upper case:
Four 3mm Phillips screws.
One 3.5mm Phillips screw.
Lift the logic board from its left edge and pull it out of the upper case.
Remove the four 8.5 mm Phillips screws securing the heat sink to the logic board.
Use the flat end of a spudger to pry the thermal sensor connector up off the logic board.
Disconnect the DC-In Board from the logic board by pulling its connector straight away from the socket on the logic board.
Use the flat end of a spudger to pry the left speaker connector up off the logic board.
Use the flat end of a spudger to pry the microphone connector up off the logic board.
Use the flat end of a spudger to separate the adhesive securing the left speaker assembly to the logic board.
Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the chip.
After the RAM chip has popped up, pull it straight out of its socket.
76 farklı kişi bu kılavuzu tamamladı.
11 Yorum
I have a A128 late 2008 13" MacBook with 2ghz processor. Can I upgrade the logic board to a 2.4ghz logic board that I buy I eBay for the same model I have a1278? Can I simply swap it out? The options for my model were 2ghz or 2.4ghz so I would like to extend the life of my Macbook by adding the 2.4ghz. So is it a simple swap out if I can get my hands on a 2.4ghz logic board from a A1278? THANKS!
I would love to have the answer too, please help us.
Just to reiterate with some more info: I have a late 2008 Macbook 13" A1278 MB466LL/A that is 2Ghz. If I bought a 2.4ghz logic board would I be able to simply swap out my current 2ghz board and replace it with this 2.4ghz board? Would it be an exact fit with no issues at all and would I just be able to boot it right back up with no software or operating system issues (ie. booting up with a completely different logic board, of course same model but just the 2.4ghz version)?? I really apprciate any advice for comfort before I invest money into my older Macbook.
Best Regards,
-Ruperto XIII Jr. M.S. M.H B.A. C.P. & M.B.A
Did anyone ever get an answer to this question?
