Giriş
Use this guide to remove the cast aluminum rear vent from your MacBook.
Parçalar
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
12 farklı kişi bu kılavuzu tamamladı.
