Giriş
Here's a logic board breakdown and chip ID for Apple's MacBook Air with M2 chip (2022).
Check out our M2 MacBook Air teardown for more details.
Many thanks to our community member CChin for his contributions!
Videoya Genel Bakış
IC identification, pt. 1:
Apple APL1109 / 339S01067 M2 64-bit octa-core applications processor w/ GPU
SK hynix H58G56AK6HX052 4 GB LPDDR5 SDRAM memory
SK hynix HN3T1BA4GAX170 256 GB NAND flash memory
Apple APL109C / 343S00554 power management
Apple APL109D / 343S00555 power management
Macronix MX25S6473F 8 MB serial NOR flash memory
Likely STMicroelectronics serial EEPROM memory
IC identification, pt. 2:
Texas Instruments SN012776B0 audio amplifier
Texas Instruments CD3217B13 USB Type-C controller w/ power delivery
Likely Apple Thunderbolt 3 redriver
Likely Texas Instruments USB 2.0 dual repeater
GigaDevice GD25Q80E 1 MB serial NOR flash memory
Winbond W25Q80DV 1 MB serial NOR flash memory
Texas Instruments TPS65157B0 display power management
IC identification, pt. 3:
Texas Instruments LP8548B1 LCD backlight driver
Renesas RAA489900A6 battery charger
USI 339S01013 WiFi 802.11a/b/g/n/ac / Bluetooth 5.0 module
Likely Renesas PWM power phase controller
Analog Devices LT8642-1 10 A synchronous step-down converter
Texas Instruments TPS621371 DC-DC converter
NXP Semiconductor SN210V NFC controller w/ secure element
Das MacBook Air M2 hat auch WLAN AX. (Unterstützte PHY-Modi: 802.11 a/b/g/n/ac/ax) Dies nur als zusätztliche Information da es in dem Text anscheinend fehlt...
IC identification, pt. 4:
Texas Instruments TPS259570DSG eFuse w/ overvoltage protection
Texas Instruments TPS259461LRPW 5.5 A eFuse
Renesas SLG461xx mixed signal array
Renesas SLG46108 mixed signal array
Likely Renesas SLG46108 mixed signal array
onsemi NCS333A single operational amplifier
Texas Instruments TPD4S311A USB Type-C port protector
IC identification, pt. 5:
Texas Instruments TVS2200 surge protection
Likely Renesas SLG59M1777V load switch
Texas Instruments TPS72748 250 mA / 4.8 V LDO regulator
Likely Renesas SLG59M1460V 2.0 A load switch
Likely Renesas 1 A dual load switch
Likely Renesas load switch
Nexperia 74AVC1T45 voltage level translator/transceiver
IC identification, pt. 6:
Nexperia LSF0101 1-bit multi-voltage level translator
Nexperia LSF0102 2-bit multi-voltage level translator
Texas Instruments LSF0102 2-ch. multi-voltage level translator
Nexperia 74AVC2T245 2-bit translating transceiver
Nexperia 74AVC4T774 4-bit translating transceiver
Diodes Incorporated 74LVC1G17FS3-7 single Schmitt trigger buffer
Nexperia 74AUP1G17 Schmitt trigger
IC identification, pt. 7:
Texas Instruments SN74AUP1G07 single buffer
Nexperia 74AUP1G34 single buffer
Nexperia 74AUP2G07 dual buffer
Nexperia 74AUP1G08 single 2-input AND gate
Nexperia 74AUP1G00 single 2-input NAND gate
Texas Instruments SN74AUP1G32 single 2-input OR gate
Nexperia 74AUP1G04 single inverter
15Kılavuz Yorumları
An accelerometer and gyro can greatly enhance the laptop’s ability to locate itself in 3D space and enhance location awareness. This can help with its mesh location network for AirTags, or along with the camera and AI it can allow the laptop to leverage RoomPlan. The gyro/accel combo can also help with Spatial Audio and calibrate itself with AirPods. Wonder what future airpod features are coming down the pipe.
Can you show the backside of this board?
Hey Caesar!
The backside of the board is shown in the last photo of the first step.
Hi, Great work! Any idea why does it have three CD3217B13 Type C controllers for two Type C ports in Step2? I see only two TBT3 and USB2 redriver as expected.
Hi Manasa,
Two of the USB type-C controllers are used for driving the two USB type-C ports while the last one is likely used for the MagSafe 3 port for charging.
To illustrate what I said above, the predicted block diagram for this M2 Macbook Air is linked here. All of the three USB type-C controllers are boxed in red. #1 and #2 boxed are used for USB type-C ports while the last one boxed (#3) is used for driving the MagSafe port.
CChin -
Do you have any idea of which die from SK Hynix those HN3T1BA4GAX170 are from? If they are like TLC 512Gb V7 176-Layers, or anything like that?
What are the physical dimensions of the motherboard?
Hello ! By any luck, is it possible to have a similar article regarding the A2337 M1 Macbook Air ?
Any idea where I can buy the heatsink from?
What about all the internal screws as well. I purchased a unit without the board. Managed to get a working board and now want to assemble it
Macbook air M2 bios chip location
Macbook air M2 not installed macos and not showing serial number recovery mode, someone any idea please
