Ana içeriğe geç
Macbook Air M2 2022 Touch ID Sensor Replacement
Neye ihtiyacın var
  1. Macbook Air M2 2022 Touch ID Sensor Replacement, Prepare your Macbook Air for disassembly: adım 1, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Prepare your Macbook Air for disassembly: adım 1, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement, Prepare your Macbook Air for disassembly: adım 1, 3 resimden 3.
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your MacBook Air and unplug all cables.
    • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
  2. Macbook Air M2 2022 Touch ID Sensor Replacement, Unfasten the lower case: adım 2, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Unfasten the lower case: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    FixMat
    $31.41
    • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
    • Two screws with a short threaded portion near the hinges
    • Two screws with a long threaded portion near the front of the MacBook
  3. Macbook Air M2 2022 Touch ID Sensor Replacement, Insert an opening pick: adım 3, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Insert an opening pick: adım 3, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. Macbook Air M2 2022 Touch ID Sensor Replacement, Release the snapping clips: adım 4, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Release the snapping clips: adım 4, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement, Release the snapping clips: adım 4, 3 resimden 3.
    • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next clip.
  5. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 5, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 5, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 5, 3 resimden 3.
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the two remaining snapping clips.
  6. Macbook Air M2 2022 Touch ID Sensor Replacement, Release the sliding tabs: adım 6, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Release the sliding tabs: adım 6, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement, Release the sliding tabs: adım 6, 3 resimden 3.
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the lower case: adım 7, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the lower case: adım 7, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the lower case: adım 7, 3 resimden 3.
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the battery connector cover: adım 8, 1 resimden 1.
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
  9. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 9, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 9, 2 resimden 2.
    • Remove the battery connector cover.
  10. Macbook Air M2 2022 Touch ID Sensor Replacement, Disconnect the battery: adım 10, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Disconnect the battery: adım 10, 2 resimden 2.
    • Use an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. Macbook Air M2 2022 Touch ID Sensor Replacement, Unfasten the trackpad cable cover: adım 11, 1 resimden 1.
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the trackpad cable cover.
  12. Macbook Air M2 2022 Touch ID Sensor Replacement, Access the trackpad press connector: adım 12, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Access the trackpad press connector: adım 12, 2 resimden 2.
    • Use a spudger or your fingers to move the trackpad cable cover out of the way so you can access the press connector underneath.
  13. Macbook Air M2 2022 Touch ID Sensor Replacement, Disconnect the trackpad cable: adım 13, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Disconnect the trackpad cable: adım 13, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the trackpad cable press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  14. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the display cable cover foam: adım 14, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the display cable cover foam: adım 14, 2 resimden 2.
    • Peel up and remove the foam pad from the lower display cable cover to reveal a hidden screw.
  15. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the cable covers: adım 15, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the cable covers: adım 15, 2 resimden 2.
    • Use a T3 Torx driver to remove the fourteen 1.5 mm screws securing the various cable covers.
  16. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 16, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 16, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 16, 3 resimden 3.
    • Use tweezers or your fingers to remove the six cable covers.
  17. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 17, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 17, 2 resimden 2.
    • Remove the four screws securing the upper display cable cover:
    • Two 2.5 mm P2 Pentalobe screws
    • Two 2.5 mm 3IP Torx Plus screws
    • During reassembly, the Pentalobe screws must thread into their holes on the plastic securing bracket.
  18. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 18, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 18, 2 resimden 2.
    • Remove the upper display cable cover and plastic securing bracket.
    • During reassembly, make sure that the upper lip of the metal cable cover slots into the plastic bracket.
  19. Macbook Air M2 2022 Touch ID Sensor Replacement, Disconnect the logic board connectors: adım 19, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Disconnect the logic board connectors: adım 19, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement, Disconnect the logic board connectors: adım 19, 3 resimden 3.
    • Use the pointed end of a spudger to pry up and disconnect both display cable press connectors.
  20. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 20, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 20, 2 resimden 2.
    • Disconnect the microphone array press connector, directly to the left of the display cable.
  21. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 21, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 21, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 21, 3 resimden 3.
    • Disconnect the left and right speaker press connectors.
  22. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 22, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 22, 2 resimden 2.
    • Insert the flat end of a spudger between the the interconnect cable and the screw post.
    • Pry up and disconnect the interconnect cable.
  23. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 23, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 23, 2 resimden 2.
    • Disconnect the MagSafe port press connector.
  24. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 24, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 24, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 24, 3 resimden 3.
    • Disconnect both Thunderbolt port press connectors.
  25. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 25, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 25, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 25, 3 resimden 3.
    • Use a pair of tweezers to grip the first antenna connector, as close to its base as possible.
    • Lift straight up to disconnect the cable.
    • The antenna connectors on the logic board are very fragile. When disconnecting the cables, pull straight up—don’t bend them to the side.
    • Repeat for the second antenna cable.
    • To reattach antenna connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
  26. Macbook Air M2 2022 Touch ID Sensor Replacement, Unfasten the logic board: adım 26, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Unfasten the logic board: adım 26, 2 resimden 2.
    • Remove the nine screws securing the logic board:
    • Three 3.8 mm T5 Torx screws
    • One 3.6 mm T5 Torx screw
    • Two 3.4 mm T5 Torx screws
    • One 3.1 mm T5 Torx screw
    • Two 2.7 mm 3IP Torx Plus screws
  27. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the logic board: adım 27, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the logic board: adım 27, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the logic board: adım 27, 3 resimden 3.
    • The logic board and its cover are connected and remove as one assembly.
    • The cover extends out from the logic board's left edge and bends easily. Don't pull the board up from this side.
    • Grip the right side of the logic board and slide it towards the trackpad until it clears the overhangs near the speakers.
    • Remove the logic board.
  28. Macbook Air M2 2022 Touch ID Sensor Replacement, Check cables during reassembly: adım 28, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Check cables during reassembly: adım 28, 2 resimden 2.
    • When you reinstall the logic board, verify that no cables get trapped under the board as you lower it into place. Check each of the seven locations carefully:
    • Right speaker cable
    • Trackpad cable
    • Display cables and microphone array cable
    • Antenna cables
    • Battery cable
    • Left speaker cable
    • USB-C and MagSafe cables
  29. Macbook Air M2 2022 Touch ID Sensor Replacement, Unfasten the left hinge cover: adım 29, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Unfasten the left hinge cover: adım 29, 2 resimden 2.
    • Use a 3IP Torx Plus driver to remove the 2.6 mm screw securing the left hinge cover.
  30. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the left hinge cover: adım 30, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the left hinge cover: adım 30, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the left hinge cover: adım 30, 3 resimden 3.
    • Grip the left hinge cover with blunt nose tweezers.
    • Pull the cover toward the bottom of the laptop and upward to free it from its recess.
    • Pull up and remove the hinge cover.
  31. Macbook Air M2 2022 Touch ID Sensor Replacement, Unfasten the right speaker: adım 31, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Unfasten the right speaker: adım 31, 2 resimden 2.
    • The right speaker will be on your left-hand side when working on the MacBook, as it's laying upside down.
    • Remove the three screws securing the right speaker:
    • Two 5.6 mm 4IP Torx Plus screws
    • One 3.5 mm T5 Torx screw
  32. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the right speaker: adım 32, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the right speaker: adım 32, 2 resimden 2.
    • Lift the right speaker straight up and remove it.
  33. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the covers: adım 33, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the covers: adım 33, 2 resimden 2.
    • Use a T3 Torx screwdriver to remove the 1.5 mm‑long screw securing the Touch ID sensor connector cover.
    • Remove the cover.
  34. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 34, 1 resimden 1.
    • Use a T3 Torx screwdriver to remove the six screws securing the Touch ID sensor and its bracket:
    • Four 2.0 mm screws
    • Two 1.7 mm screws
  35. Macbook Air M2 2022 Touch ID Sensor Replacement: adım 35, 1 resimden 1.
    • Remove the Touch ID sensor bracket.
  36. Macbook Air M2 2022 Touch ID Sensor Replacement, Disconnect the Touch ID sensor: adım 36, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Disconnect the Touch ID sensor: adım 36, 2 resimden 2.
    • Use a spudger to pry up and disconnect the Touch ID sensor press connector from the daughterboard.
  37. Macbook Air M2 2022 Touch ID Sensor Replacement, Separate the cable adhesive: adım 37, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Separate the cable adhesive: adım 37, 2 resimden 2.
    Tesa 61395 Tape
    $5.99
    • Light adhesive secures the Touch ID sensor cable to the frame.
    • Use tweezers or your fingers to peel the Touch ID sensor cable from the frame.
    • If your new Touch ID sensor's cable comes with adhesive, remove the plastic liner and press the cable into place on the frame.
    • If the cable doesn't have adhesive, use a strip of double-sided tape such as Tesa Tape to secure it to the frame.
  38. Macbook Air M2 2022 Touch ID Sensor Replacement, Open your MacBook: adım 38, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Open your MacBook: adım 38, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement, Open your MacBook: adım 38, 3 resimden 3.
    • Open your MacBook until the main body stands up on its own.
  39. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the Touch ID sensor: adım 39, 2 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Remove the Touch ID sensor: adım 39, 2 resimden 2.
    • Pull the Touch ID sensor away from the frame while guiding the cable through its slot.
    • Remove the sensor.
  40. Macbook Air M2 2022 Touch ID Sensor Replacement, Reassembly information: adım 40, 3 resimden 1. Macbook Air M2 2022 Touch ID Sensor Replacement, Reassembly information: adım 40, 3 resimden 2. Macbook Air M2 2022 Touch ID Sensor Replacement, Reassembly information: adım 40, 3 resimden 3.
    • Guide the new Touch ID sensor's cable through its slot in the fame.
    • Make sure the cable is properly oriented so the press connector lines up with its socket.
    • Hold the cable with one hand and use your other hand to align the new sensor in its recess.
    • Once the sensor is aligned, gently pull the cable away from the MacBook to secure the sensor against the frame.
    • Continue holding the sensor in place by its cable and slowly close the MacBook.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Spencer Day
149.412 İtibar
995 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.612 adet Kılavuz yazıldı
1Rehber Yorum
Thank you! These instructions were brilliant, super easy to follow and very accurate. I accidentally spilled liquid on my keyboard and the only issue was a stuck power button which put it into a permanent boot loop (recovery menu). Apple wanted well over $1000 to back up the data and fix it. They charge a flat fee when there is liquid damage and replace all effected components. I was pretty certain I only had an issue with the power button. For $35 I bought a new button and followed your instructions. Works like a champ.
Jim - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 107
Son 30 gün: 360
Her zaman: 6,183
