Giriş
In this replacement guide you're going to learn how to replace a faulty speaker. It's important to go to the trouble shooting page first in order to know that you need to replace the speaker and it's not some other issue that you actually need to solve first.
Neye ihtiyacın var
Place the device face down on a flat surface.
Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
Lay the back panel on a flat surface with the battery, motherboard, and speaker facing up.
Use a plastic opening tool to gently pull the battery away from the back panel in order to remove the adhesive that helps the battery stick to the panel.
Use a soldering iron to desolder the two wires that connect the speaker to the motherboard.
Follow the How to Solder and Desolder Connections guide for help.
