Ana içeriğe geç
The MakerBot Digitizer was a 2013 desktop 3D scanner aimed at the consumer and prosumer markets, providing an easy-to-use solution for creating digital models of real-world objects for 3D printing. In 2024, LiDAR technology is more readily available. Using photogrammetry and a turntable, one can achieve fantastic results with a mere phone. I cannibalized my Digitizer for its frame and stepper, using a Raspberry Pico W to control the Moons' stepper motor. This is how I took my Digitizer apart.
Neye ihtiyacın var
Aletler
Bu teardown bir tamir kılavuzu değildir. Makerbot Digitizer cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Makerbot Digitizer Teardown, Remove rear screws and face plate: adım 1, 3 resimden 1. Makerbot Digitizer Teardown, Remove rear screws and face plate: adım 1, 3 resimden 2. Makerbot Digitizer Teardown, Remove rear screws and face plate: adım 1, 3 resimden 3.
    • There are four black T15 screws that hold the front panel on.
    • Do not confuse these with the two laser adjustment screws.
    • The ones you need to loosen are perpendicular with the frame; not angled.
    • Once the screws are loosened, the front panel simply pulls off.
  2. Makerbot Digitizer Teardown, Remove turntable: adım 2, 3 resimden 1. Makerbot Digitizer Teardown, Remove turntable: adım 2, 3 resimden 2. Makerbot Digitizer Teardown, Remove turntable: adım 2, 3 resimden 3.
    • Pop the cap out with a flat pry tool.
    • Loosen the T15 screw. You don't need to remove it.
    • Pry on both sides of the turntable so that it comes up and out.
    • To reinstall it, make sure the motor-facing side goes in first, to make good contact with the stepper motor gear teeth.
    • If the stepper motor-facing side does not get reinstalled first, the table will not sit properly.
  3. Makerbot Digitizer Teardown, Remove top panel: adım 3, 2 resimden 1. Makerbot Digitizer Teardown, Remove top panel: adım 3, 2 resimden 2.
    • There are eight T15 screws holding the top panel in place.
    • Once these are all loosened, the top panel simply lifts off.
    • Your electronics will look different than mine. Everything should now be accessible.
  4. Makerbot Digitizer Teardown, Inspect the stepper motor: adım 4, 1 resimden 1.
    • Mine is a 'Moons 14HK2401-74N'.
    • The '74N' seems to indicate the voltage required, in this case, 12V.
Job McKee
241 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 183
