Ana içeriğe geç
Makita DT01 Battery Replacement
Victoria Scira
Victoria Scira ve 2 diğer katkıda bulunanlar
En son May 16, 2017 tarihinde güncellendi
1 dakika
Çok kolay
This guide will help you remove the battery from your drill.
  1. Makita DT01 Battery Replacement, Battery: adım 1, 3 resimden 1. Makita DT01 Battery Replacement, Battery: adım 1, 3 resimden 2. Makita DT01 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Lay the device down on its side.
  2. Makita DT01 Battery Replacement: adım 2, 1 resimden 1.
    • Pinch the indents on both sides of the battery.
  3. Makita DT01 Battery Replacement: adım 3, 1 resimden 1.
    • Pull the battery out of the drill
    • Recharge or completely replace the battery
    • Make sure that the battery is removed before further working on the drill. This is so the drill doesn't accidentally activate.
Sonuç
Victoria Scira
226 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Replacement for Makita DT01 Power Tool Battery
Type: Li-ion
Volt: 10.8V
Capacity: 3000mAh
Color: Black
Weight: 166g
Dimension: 50.75 x 50.20 x 77.80mm
You can contact this seller for a lower price if you want a quantity purchase of Makita DT01 replacement batteries on https://www.drill-battery.net.au/buybatt...
Drillbatterycomau - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 568
