Ana içeriğe geç
Maquet Servo-U O2 Supply Replacement
  1. Maquet Servo-U O2 Supply Replacement, O2 Supply: adım 1, 1 resimden 1.
    • Turn the inspiratory channel lock one quarter of a turn to release.
    • Lift off the inspiratory channel cover.
    • WARNING! The inspiratory channel cover shall be kept in place once maintenance has been performed. Otherwise the gas modules can be affected and deliver the wrong flow.
    FixBot'a Sor
    Yorum Ekle
  2. Maquet Servo-U O2 Supply Replacement: adım 2, 1 resimden 1.
    • Lower the locking catch.
    FixBot'a Sor
    Yorum Ekle
  3. Maquet Servo-U O2 Supply Replacement: adım 3, 2 resimden 1. Maquet Servo-U O2 Supply Replacement: adım 3, 2 resimden 2.
    • Disconnect the O2 cell connector.
    • Lift and discard the O2 cell with the rubber seal to special waste and/or remove and discard the bacterial filter to hazardous waste.
    FixBot'a Sor
    Yorum Ekle
  4. Maquet Servo-U O2 Supply Replacement: adım 4, 1 resimden 1.
    • Ensure that the new rubber seal is intact, then firmly put in a new bacterial filter.
    FixBot'a Sor
    Yorum Ekle
  5. Maquet Servo-U O2 Supply Replacement: adım 5, 1 resimden 1.
    • Connect the O2 cell connector.
    • Put the O2 cell in position.
    • Close the locking catch.
    FixBot'a Sor
    Yorum Ekle
  6. Maquet Servo-U O2 Supply Replacement: adım 6, 1 resimden 1.
    • Put the inspiratory channel cover in position.
    • Tighten the inspiratory channel lock.
    • Perform a pre-use check stated in Troubleshooting Page.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Cassandra Aarrestad
627 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G2, Paton Spring 2020 Cal Poly, Team S7-G2, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G2
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 51
Her zaman: 2,963
