Ana içeriğe geç
Martian Victory Analog Watch Battery Replacement
Neye ihtiyacın var
  1. Martian Victory Analog  Watch Battery Replacement, Back Plate: adım 1, 2 resimden 1. Martian Victory Analog  Watch Battery Replacement, Back Plate: adım 1, 2 resimden 2.
    • Unscrew the four 3.4 mm flat head screws
    FixBot'a Sor
    Yorum Ekle
  2. Martian Victory Analog  Watch Battery Replacement: adım 2, 1 resimden 1.
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
    FixBot'a Sor
    Yorum Ekle
  3. Martian Victory Analog  Watch Battery Replacement, Lithium Battery: adım 3, 1 resimden 1.
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
    FixBot'a Sor
    Yorum Ekle
  4. Martian Victory Analog  Watch Battery Replacement: adım 4, 1 resimden 1.
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
    FixBot'a Sor
    Yorum Ekle
  5. Martian Victory Analog  Watch Battery Replacement, Motherboard: adım 5, 1 resimden 1.
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
    FixBot'a Sor
    Yorum Ekle
  6. Martian Victory Analog  Watch Battery Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
    FixBot'a Sor
    Yorum Ekle
  7. Martian Victory Analog  Watch Battery Replacement: adım 7, 1 resimden 1.
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
    FixBot'a Sor
    Yorum Ekle
  8. Martian Victory Analog  Watch Battery Replacement: adım 8, 3 resimden 1. Martian Victory Analog  Watch Battery Replacement: adım 8, 3 resimden 2. Martian Victory Analog  Watch Battery Replacement: adım 8, 3 resimden 3.
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Martian Victory Analog  Watch Battery Replacement: adım 9, 2 resimden 1. Martian Victory Analog  Watch Battery Replacement: adım 9, 2 resimden 2.
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. Martian Victory Analog  Watch Battery Replacement, Analog Watch Battery: adım 10, 1 resimden 1.
    • Use a spudger to lift the battery from the back case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
David Miller
246 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S3G3
4 Üyeler
8 adet Kılavuz yazıldı
3Kılavuz Yorumları
I am researching for methods to change batteries on a watch. Would like to thank you for this piece. It is really good. However, you have used some tools in your tutorial. but since they pins and scissors are in everyone's home, making your way easy
I shall be writing a post in the same topic. and would love to feature your guide on it..
Thanks
Ronald Mckim
Owner: http://www.mywatchvilla.com/
Ronald Mckim - Yanıt Paylaş
@ronaldmckim, you may embed our guide using the instructions here: https://ifixit.org/blog/8474/embed-guide.... For our content licensing policies, see: Content Licensing.
Cynthia Replogle - Yanıt Paylaş
Hi.. Thank you for the detailed steps, it really helped a lot in replacing the analog battery ourselves
However, now we are not able to place the mother board back in its place, hence wanted to check if there is any tips or steps or screenshots how we can place it back?
Ashwin kochar - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 43
Her zaman: 9,990
