Ana içeriğe geç
Martian Victory LED Screen Replacement
Neye ihtiyacın var
  1. Martian Victory LED Screen Replacement, Back Plate: adım 1, 2 resimden 1. Martian Victory LED Screen Replacement, Back Plate: adım 1, 2 resimden 2.
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory LED Screen Replacement: adım 2, 1 resimden 1.
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory LED Screen Replacement, Lithium Battery: adım 3, 1 resimden 1.
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory LED Screen Replacement: adım 4, 1 resimden 1.
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory LED Screen Replacement, LED Screen: adım 5, 1 resimden 1.
    • Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
  6. Martian Victory LED Screen Replacement: adım 6, 1 resimden 1.
    • With a pair of tweezers, carefully remove the ribbon strip connection.
  7. Martian Victory LED Screen Replacement: adım 7, 1 resimden 1.
    • Remove the screw driver holding the LED screen and Speaker in place.
  8. Martian Victory LED Screen Replacement: adım 8, 1 resimden 1.
    • Insert a small flat screw driver under the speaker in order to remove it.
  9. Martian Victory LED Screen Replacement: adım 9, 2 resimden 1. Martian Victory LED Screen Replacement: adım 9, 2 resimden 2.
    • Using tweezers, remove the speaker and move off to the side.
  10. Martian Victory LED Screen Replacement: adım 10, 2 resimden 1. Martian Victory LED Screen Replacement: adım 10, 2 resimden 2.
    • Place a small flat head screwdriver under the LED screen, and carefully push it out of it's socket.
  11. Martian Victory LED Screen Replacement: adım 11, 1 resimden 1.
    • Remove final connection to accelerometer. The LED screen is now separated from the device.
Sonuç
Robert Sanchez
201 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S3G3
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 194
