Ana içeriğe geç
Master and Dynamic MW50 Battery Replacement
Neye ihtiyacın var
  1. Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: adım 1, 3 resimden 1. Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: adım 1, 3 resimden 2. Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: adım 1, 3 resimden 3.
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Battery Replacement: adım 3, 1 resimden 1.
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Battery Replacement, Battery: adım 4, 2 resimden 1. Master and Dynamic MW50 Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the tape attaching the thicker white wire to the battery. You may consider keeping the tape to reattach the wire later.
  5. Master and Dynamic MW50 Battery Replacement: adım 5, 1 resimden 1.
    • Desolder the two wires circled here.
  6. Master and Dynamic MW50 Battery Replacement: adım 6, 2 resimden 1. Master and Dynamic MW50 Battery Replacement: adım 6, 2 resimden 2.
    • Use an iFixit opening tool or something similar to pry out the battery.
    • There are two small tabs circled here that are holding the battery in. Push these down while prying to make the battery come out easier.
Sonuç
Tyler Guffey
208 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G4, White Winter 2019 Cal Poly, Team S1-G4, White Winter 2019 üyesi
CPSU-WHITE-W19S1G4
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Hi, do you know where it’s possible to buy replacement batteries??
Mike - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 19
Son 30 gün: 38
Her zaman: 1,760
