Ana içeriğe geç
Master and Dynamic MW50 Charging Port Replacement
Neye ihtiyacın var
  1. Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: adım 1, 3 resimden 1. Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: adım 1, 3 resimden 2. Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: adım 1, 3 resimden 3.
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Charging Port Replacement: adım 2, 1 resimden 1.
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Charging Port Replacement: adım 3, 1 resimden 1.
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Charging Port Replacement, Charging Port: adım 4, 2 resimden 1. Master and Dynamic MW50 Charging Port Replacement, Charging Port: adım 4, 2 resimden 2.
    • Remove the two 2mm screws pictured with a JIS #00 screwdriver.
    • Gently pull the silver cover off of the ear piece.
  5. Master and Dynamic MW50 Charging Port Replacement: adım 5, 1 resimden 1.
    • Remove the two 2mm screws shown with a JIS #00 screwdriver.
  6. Master and Dynamic MW50 Charging Port Replacement: adım 6, 1 resimden 1.
    • Lift up the mother board with the attached charging port to see the soldering points. You must desolder these points in order to detach (and re-attach) the charging port.
Sonuç
Tyler Guffey
208 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G4, White Winter 2019 Cal Poly, Team S1-G4, White Winter 2019 üyesi
CPSU-WHITE-W19S1G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 305
