Ana içeriğe geç
Master and Dynamic MW50 Right/Left Speaker Replacement
Neye ihtiyacın var
  1. Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: adım 1, 3 resimden 1. Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: adım 1, 3 resimden 2. Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: adım 1, 3 resimden 3.
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Right/Left Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Right/Left Speaker Replacement: adım 3, 1 resimden 1.
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Right/Left Speaker Replacement, Right/Left Speaker: adım 4, 1 resimden 1.
    • Desolder the two wires connected to the speaker.
  5. Master and Dynamic MW50 Right/Left Speaker Replacement: adım 5, 1 resimden 1.
    • Use a heating gun to remove the glue from the speaker.
    • Once the glue is removed, gently pull out the speaker.
Sonuç
Katie Dunnigan
85 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G4, White Winter 2019 Cal Poly, Team S1-G4, White Winter 2019 üyesi
CPSU-WHITE-W19S1G4
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
This is awesome but Master & Dynamic don’t sell replacement 45mm 32 ohm drivers and won’t share the specs.
If anyone know where to get a replacement which will work well with these headphones please share!!!
paul
bloodygoose@icloud.com
psullivan_au - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 656
