Ana içeriğe geç
Mattel Loopz Speaker Replacement
Neye ihtiyacın var
  1. Mattel Loopz Speaker Replacement, Batteries: adım 1, 1 resimden 1.
    • Use a No. 2 Phillips head screwdriver to take out the 1/4" screw that holds the battery cover in place on the bottom of the device.
  2. Mattel Loopz Speaker Replacement: adım 2, 1 resimden 1.
    • Take out the 4 AA Batteries.
  3. Mattel Loopz Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Remove red screw covers (13 total) using spudger.
  4. Mattel Loopz Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the thirteen 12.7mm screws with a #1 Phillips screwdriver.
  5. Mattel Loopz Speaker Replacement: adım 5, 1 resimden 1.
    • Remove 6 white caps using spudger to reveal screws underneath.
  6. Mattel Loopz Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the six 16mm screws with a #1 Phillips screwdriver.
  7. Mattel Loopz Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the white cover. Be sure to remove the front and the back.
  8. Mattel Loopz Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the black, plastic cover to reveal the internal electronics as shown.
  9. Mattel Loopz Speaker Replacement: adım 9, 1 resimden 1.
    • Remove the two 6.4mm screws with a #1 Phillips screwdriver.
  10. Mattel Loopz Speaker Replacement: adım 10, 1 resimden 1.
    • Remove the speaker as shown.
  11. Mattel Loopz Speaker Replacement: adım 11, 1 resimden 1.
    • Use a soldering iron to desolder the red and black speaker wires from the speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Trevor Lasiter
227 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Freund Spring 2018 IUPUI, Team S1-G2, Freund Spring 2018 üyesi
IUPUI-FREUND-S18S1G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 432
