Ana içeriğe geç
Maze Speed SSB-508 Screen Replacement
Neye ihtiyacın var
  1. Maze Speed SSB-508 Screen Replacement, Motherboard: adım 1, 3 resimden 1. Maze Speed SSB-508 Screen Replacement, Motherboard: adım 1, 3 resimden 2. Maze Speed SSB-508 Screen Replacement, Motherboard: adım 1, 3 resimden 3.
    • Remove the back cover by inserting the plastic opening tool at the bottom left corner of the device.
  2. Maze Speed SSB-508 Screen Replacement: adım 2, 2 resimden 1. Maze Speed SSB-508 Screen Replacement: adım 2, 2 resimden 2.
    • Remove fifteen 2mm Phillips #00 screws.
  3. Maze Speed SSB-508 Screen Replacement: adım 3, 3 resimden 1. Maze Speed SSB-508 Screen Replacement: adım 3, 3 resimden 2. Maze Speed SSB-508 Screen Replacement: adım 3, 3 resimden 3.
    • Lift the plastic opening tool up at the bottom left corner to create the gap.
    • Repeat this through all corners to remove the internal casing.
  4. Maze Speed SSB-508 Screen Replacement: adım 4, 3 resimden 1. Maze Speed SSB-508 Screen Replacement: adım 4, 3 resimden 2. Maze Speed SSB-508 Screen Replacement: adım 4, 3 resimden 3.
    • Unscrew the 2mm screw at the bottom right of the motherboard.
    • Remove the internal antenna casing from the motherboard.
  5. Maze Speed SSB-508 Screen Replacement: adım 5, 2 resimden 1. Maze Speed SSB-508 Screen Replacement: adım 5, 2 resimden 2.
    • Unplug the speaker at the top of the motherboard.
  6. Maze Speed SSB-508 Screen Replacement: adım 6, 2 resimden 1. Maze Speed SSB-508 Screen Replacement: adım 6, 2 resimden 2.
    • Desolder the gold ribbon that is connected to the motherboard at the bottom left corner.
  7. Maze Speed SSB-508 Screen Replacement: adım 7, 3 resimden 1. Maze Speed SSB-508 Screen Replacement: adım 7, 3 resimden 2. Maze Speed SSB-508 Screen Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to remove cable from the ZIF connectors located at the bottom left of the motherboard.
    • Use the tweezers to remove the second cable from ZIF connector located to the right of the speaker that you unplugged in step five.
    • ZIF connector stands for Zero Insertion Force. Flip the small locking tap before removing the cable.
  8. Maze Speed SSB-508 Screen Replacement: adım 8, 2 resimden 1. Maze Speed SSB-508 Screen Replacement: adım 8, 2 resimden 2.
    • At this point, the motherboard should be able to be lifted up from the bottom.
    • Use the tweezers to dislodge the speaker.
    • After the speaker is dislodged, flip the motherboard up so that you can see the cable.
    • Using a soldering tool, desolder the cable from the back of the motherboard.
  9. Maze Speed SSB-508 Screen Replacement: adım 9, 1 resimden 1.
    • Remove the motherboard from the back.
  10. Maze Speed SSB-508 Screen Replacement, Screen: adım 10, 2 resimden 1. Maze Speed SSB-508 Screen Replacement, Screen: adım 10, 2 resimden 2.
    • Apply the heated iOpener to all sides of the screen (left, right, top, and bottom) for 90 seconds (or more if necessary) to soften the adhesive.
  11. Maze Speed SSB-508 Screen Replacement: adım 11, 3 resimden 1. Maze Speed SSB-508 Screen Replacement: adım 11, 3 resimden 2. Maze Speed SSB-508 Screen Replacement: adım 11, 3 resimden 3.
    • Use a Jimmy's flexible steel blade to separate the screen from the frame. Insert the blade between the frame and screen then carefully lift using the blade.
    • Gently lift the glass screen and remove from the frame.
  12. Maze Speed SSB-508 Screen Replacement: adım 12, 3 resimden 1. Maze Speed SSB-508 Screen Replacement: adım 12, 3 resimden 2. Maze Speed SSB-508 Screen Replacement: adım 12, 3 resimden 3.
    • There will be a thin flat cable at the top of the screen in which you need to carefully peel back.
  13. Maze Speed SSB-508 Screen Replacement: adım 13, 1 resimden 1.
    • Move the connecting wire through the hole at the top frame.
    • Then, remove the glass screen and replace with the new one.
Sonuç
To reassemble your device, follow these instructions carefully in reverse order.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,154
