Ana içeriğe geç
Meizu MX3 Battery Replacement
Neye ihtiyacın var
  1. Meizu MX3 Battery Replacement, Removing the Back Cover: adım 1, 3 resimden 1. Meizu MX3 Battery Replacement, Removing the Back Cover: adım 1, 3 resimden 2. Meizu MX3 Battery Replacement, Removing the Back Cover: adım 1, 3 resimden 3.
    • Insert the plastic opening tool in between the charging port and the back case of the device. Slowly move the tool to the left of the device until you come the top by the power button.
    • Using a paper clip or pointed-edge spudger push in the pin located in the bottom right-hand corner on the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Meizu MX3 Battery Replacement, Removing the Screws in the Internal Casing: adım 2, 3 resimden 1. Meizu MX3 Battery Replacement, Removing the Screws in the Internal Casing: adım 2, 3 resimden 2. Meizu MX3 Battery Replacement, Removing the Screws in the Internal Casing: adım 2, 3 resimden 3.
    • Using one of the small Phillips screwdriver bits provided unscrew the 11 screws present on the protective plastic plate under the device case.
    FixBot'a Sor
    Yorum Ekle
  3. Meizu MX3 Battery Replacement, Removing the Battery: adım 3, 3 resimden 1. Meizu MX3 Battery Replacement, Removing the Battery: adım 3, 3 resimden 2. Meizu MX3 Battery Replacement, Removing the Battery: adım 3, 3 resimden 3.
    • After the 11 screws are loosened use the plastic opening tool and gently pry the protective plate from the back of the device.
    • Once the plate is off, use the same tool to gently remove the 3 ribbon cables located directly above the battery.
    • On the left side of the battery on the phone case, there is a groove where the plastic opening tool can be inserted to pry the battery up and out.
    • The battery might be glued to the phone so exercise caution. Puncturing the battery can cause it to explode and cause a fire.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Mandela Robin
876 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-2, Remmell Fall 2014 USF Tampa, Team 15-2, Remmell Fall 2014 üyesi
USFT-REMMELL-F14S15G2
4 Üyeler
21 adet Kılavuz yazıldı
1Rehber Yorum
The battery cover of my mx3 had 9 screws visibles. The last 2, the top and bottom middle screws, were hidden under a layer of paint and didn't look like screws. Just push the screw driver in and break the paint layer. I would guess that this is the equivalent of a warranty seal, so if your phone is still under warranty think carefully before you do them.
Guillaume - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 49
Her zaman: 6,282
