Giriş
You have to replace the heater if the coffee is too cold or the flow is - mostly disturbed by limescale.
Neye ihtiyacın var
Remove the water tank and drainage tray.
Remove the side cover and remove the brewing unit.
Remove all coffee beans.
Press carefully into the slits on the sides using a minus screwdriver or a flat metal spatula, to release the clasps on the upper surface. These may be well tight and you have to use some force.
You should have created a separation between the upper surface and side panels. Now lever the upper covering away using a plastic tool. This may be quite stuck and you may apply some force.
Place a plastic tool in the crack between front panel and left side panel and widen it. Then push the side panel to the back. The side panel will be quite stuck and you may apply some force to do this.
Remove the hose from the water tank to the pump.
Remove the side panel.
Hi, I have a Melitta Caffeo Solo E950 and had a problem with the switch (it said that the drainage tray was always in while I removed it).
I was able to access the switch right after the step 4 behind the side panel.
Paul
Do you mean this one: Melitta Caffeo Solo Mikroschalter an der Tropfschale tauschen?
VauWeh -
Repeat the steps in reverse order to reassemble your device.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
2 Yorum
Sehr schöne Anleitung! Stehe gerade vor der selben Maschine und prüfe gerade warum kein Wasser herauskommt.
Schläuche wurden geprüft, Flowmeter geprüft, ist alles freigängig. Pumpe drückt Wasser bis zum Erhitzer. Ich denke dieser ist verkalkt.
Schöne Anleitung, enthält alles was man braucht!
Zum Prüfen einfach reinblasen. Muss ziemlich leicht gehen.
VauWeh -
bei meiner Maschine muss ich die Schale 3-4 mal rausnehmen / einsetzten damit sich das Signal von „dauerhaft an“ auf „blinkend“ einstellt, deutet das daraufhin das der mikroschalter getauscht werden sollte. Übrigens, danke für das tolle Tutorial ..lg Tom
Hans-A Shole - Yanıt
Problem ist behoben, Schalter getauscht, Position des Schalters ist bei der Caffeo Solo 950 sehr gut erreichbar. Alter Schalter konnte auch wieder gangfähig gemacht werden und dient nun als Ersatz.
