Ana içeriğe geç
Memorex CD Alarm Clock Radio Antenna Replacement
Neye ihtiyacın var
  1. Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: adım 1, 3 resimden 1. Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: adım 1, 3 resimden 2. Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: adım 1, 3 resimden 3.
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio Antenna Replacement: adım 2, 3 resimden 1. Memorex CD Alarm Clock Radio Antenna Replacement: adım 2, 3 resimden 2. Memorex CD Alarm Clock Radio Antenna Replacement: adım 2, 3 resimden 3.
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio Antenna Replacement, Antenna: adım 3, 1 resimden 1.
    • Locate the small silver transistor between the front left speaker and the tuning knob. The antenna should be attached directly below the transistor.
    • Deolder the antenna wire from the circuit board, and remove the wire.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 839
