Giriş
The steps in this guide will instruct you on how to disassemble the boombox and remove the speakers. In the guide, we focus on removing the left speaker, but the instructions given are also applicable to the right speaker. Extensive disassembly and very basic soldering is required. The environment preferred is a clear worktable space.
Neye ihtiyacın var
Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
Use a Phillips #1 screwdriver to unscrew the two 8 mm screws on the speaker housing.
4 farklı kişi bu kılavuzu tamamladı.
