Ana içeriğe geç
MerchSource the Black Series Boat Racer Battery Cable Replacement
Neye ihtiyacın var
  1. MerchSource the Black Series Boat Racer Battery Cable Replacement, Battery Cable: adım 1, 2 resimden 1. MerchSource the Black Series Boat Racer Battery Cable Replacement, Battery Cable: adım 1, 2 resimden 2.
    • Turn the remote controller over to the back.
  2. MerchSource the Black Series Boat Racer Battery Cable Replacement: adım 2, 1 resimden 1.
    • Slide the battery cover off.
  3. MerchSource the Black Series Boat Racer Battery Cable Replacement: adım 3, 2 resimden 1. MerchSource the Black Series Boat Racer Battery Cable Replacement: adım 3, 2 resimden 2.
    • Remove both AA-batteries.
  4. MerchSource the Black Series Boat Racer Battery Cable Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver, remove the four screws located in the four corners of the back of the remote controller.
    • Screw length is 6 mm.
  5. MerchSource the Black Series Boat Racer Battery Cable Replacement: adım 5, 3 resimden 1. MerchSource the Black Series Boat Racer Battery Cable Replacement: adım 5, 3 resimden 2. MerchSource the Black Series Boat Racer Battery Cable Replacement: adım 5, 3 resimden 3.
    • Separate the two halves of the remote controller.
  6. MerchSource the Black Series Boat Racer Battery Cable Replacement: adım 6, 1 resimden 1.
    • Solder the wire to reconnect it.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 216
