Giriş
This guide shows how to remove and replace a drifting or broken joystick (aka thumbstick) for your Meta Quest 2 controller.
If you're experiencing controller drift, or your joystick isn't responsive, you'll likely need to replace the joystick.
The joystick is nested behind the controller board, requiring you to disassemble the entire controller to access it.
This guide is written with the right controller. If you're repairing the left controller, you can still use this guide, as the procedure is identical.
Neye ihtiyacın var
Use your fingers to slide the battery cover down towards the strap end of the controller.
Remove the battery cover.
Use your fingers to grasp the wrist strap near the anchor peg.
Lift the wrist strap anchor peg straight out of its recess.
Remove the wrist strap.
Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
The controller faceplate is secured with adhesive and three friction pegs.
Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
Slide the opening tool to the base of the ring shell to loosen the adhesive.
Use a Torx T5 driver to remove the four screws securing the controller ring shell to the controller:
Two 4.7 mm‑long screws
Two 5.9 mm‑long screws
Use your fingers to grab the end of the ring shell that doesn’t have the white alignment square.
Gently lift the ring shell up and away from the controller to unclip it from the controller.
Remove the controller ring shell.
Use a Torx T5 driver to remove the five screws:
One 11.5 mm‑long screw
Three 5.9 mm‑long screws
One 18.2 mm‑long screw
Bu adımda kullanılan alet:Tweezers$4.99
Use tweezers and your fingers to peel the battery information label out from the battery compartment.
Use a Torx T5 driver to remove the four 5.9 mm‑long screws securing the side shell to the controller:
Three screws inside the battery compartment
One screw near the corner of the battery compartment
Guide the looped part of the side shell through the screw post gap.
Remove the side shell.
Spread the screw post wide enough to loop the side shell back around it.
Be careful not to pinch the antenna cable or the tracking flex cable as you reposition the side shell.
Use a spudger or an opening pick to gently pry the shell from the battery compartment side first.
Once it pops open, turn the controller over to remove the front shell.
Use a driver bit (such as the Torx T5) or the point of a spudger to push the front trigger pin out from the side shown. Pushing from the opposite side can cause the pin to rip the sensor cable.
Use a clean fingernail or tweezers to flip up the ZIF socket's lock bar securing the outer tracking flex cable.
Insert one arm of a pair of tweezers under the metal neck of the antenna cable.
Pry straight up to disconnect the antenna from the controller board.
Gently pull the antenna to unclip it from its grounding clip.
Use your fingers to twist the battery shell slightly so that its edge near the thumbstick clicks out of place.
Use a Torx T5 driver to remove the four 7.5 mm‑long screws securing the controller board.
Use your fingers to lift the controller board out of the shell and remove it.
Use your fingers or tweezers to remove the joystick.
42 farklı kişi bu kılavuzu tamamladı.
11Kılavuz Yorumları
When replacing the joystick, make sure you place the metal cover on the right side, the joystick goes under the circuit board, and make sure the little metal flap is bent enough, also make sure the screws are tight.
id recommend this video so you get more what i mean, although it doesn't show exactly that i mean.
https://youtu.be/kQ2-XYEbOKY?t=98
otherwise you wont have the touch pad on the joystick, it'll still work good, just no sensing if you have your finger on it
You dont need to remove the pin/take of the tigger, if youre carful and paitent
id say its safer to leave it in
Can confirm. I looked at this guide before looking at any videos (all of which do not take the trigger out) and I must have bent the pin/spring when putting it back in because my trigger won't go back up now. I also broke the front shell alignment peg when going back to try to try again. Please update this guide so this doesn't happen to anyone else.
