Ana içeriğe geç
Meta Quest 2 Controller Thumbgrip Replacement
Neye ihtiyacın var
  1. Meta Quest 2 Controller Thumbgrip Replacement, Remove the battery cover: adım 1, 3 resimden 1. Meta Quest 2 Controller Thumbgrip Replacement, Remove the battery cover: adım 1, 3 resimden 2. Meta Quest 2 Controller Thumbgrip Replacement, Remove the battery cover: adım 1, 3 resimden 3.
    • Use your fingers to slide the battery cover down towards the strap end of the controller.
    • Remove the battery cover.
    • If you're taking the controller apart for repairs, remove the batteries in the controller.
  2. Meta Quest 2 Controller Thumbgrip Replacement, Loosen the faceplate adhesive: adım 2, 1 resimden 1.
    • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
  3. Meta Quest 2 Controller Thumbgrip Replacement, Loosen the controller faceplate: adım 3, 3 resimden 1. Meta Quest 2 Controller Thumbgrip Replacement, Loosen the controller faceplate: adım 3, 3 resimden 2. Meta Quest 2 Controller Thumbgrip Replacement, Loosen the controller faceplate: adım 3, 3 resimden 3.
    • The controller faceplate is secured with adhesive and three friction pegs.
    • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
    • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
    • Slide the opening tool to the base of the ring shell to loosen the adhesive.
  4. Meta Quest 2 Controller Thumbgrip Replacement: adım 4, 2 resimden 1. Meta Quest 2 Controller Thumbgrip Replacement: adım 4, 2 resimden 2.
    • Use an opening tool to pry up on the seam to loosen the first friction peg.
  5. Meta Quest 2 Controller Thumbgrip Replacement: adım 5, 2 resimden 1. Meta Quest 2 Controller Thumbgrip Replacement: adım 5, 2 resimden 2.
    • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
    • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
  6. Meta Quest 2 Controller Thumbgrip Replacement, Remove the faceplate: adım 6, 3 resimden 1. Meta Quest 2 Controller Thumbgrip Replacement, Remove the faceplate: adım 6, 3 resimden 2. Meta Quest 2 Controller Thumbgrip Replacement, Remove the faceplate: adım 6, 3 resimden 3.
    • Remove the controller faceplate.
    • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
  7. Meta Quest 2 Controller Thumbgrip Replacement, Remove the thumbgrip: adım 7, 2 resimden 1. Meta Quest 2 Controller Thumbgrip Replacement, Remove the thumbgrip: adım 7, 2 resimden 2.
    • Use your fingers to pull the thumbgrip straight off of the thumbstick and remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Arthur Shi
310.054 İtibar
701 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.629 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 21
Son 30 gün: 86
Her zaman: 1,815
