Ana içeriğe geç
Meta Quest 2 Fan Assembly Replacement
Neye ihtiyacın var
  1. Meta Quest 2 Fan Assembly Replacement, Power off your Meta Quest 2: adım 1, 1 resimden 1.
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Fan Assembly Replacement, Remove the facial interface: adım 2, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement, Remove the facial interface: adım 2, 2 resimden 2.
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Fan Assembly Replacement: adım 3, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement: adım 3, 2 resimden 2.
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Fan Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Fan Assembly Replacement, Unclip the side straps: adım 5, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement, Unclip the side straps: adım 5, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement, Unclip the side straps: adım 5, 3 resimden 3.
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Fan Assembly Replacement: adım 6, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement: adım 6, 2 resimden 2.
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Fan Assembly Replacement, Remove the top strap: adım 7, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement, Remove the top strap: adım 7, 2 resimden 2.
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Fan Assembly Replacement, Remove the head strap: adım 8, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement, Remove the head strap: adım 8, 2 resimden 2.
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Fan Assembly Replacement, Remove the eyepiece trim screws: adım 9, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement, Remove the eyepiece trim screws: adım 9, 2 resimden 2.
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Fan Assembly Replacement, Release the eyepiece trim clips: adım 10, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement, Release the eyepiece trim clips: adım 10, 2 resimden 2.
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Fan Assembly Replacement: adım 11, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement: adım 11, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement: adım 11, 3 resimden 3.
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Fan Assembly Replacement: adım 12, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement: adım 12, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement: adım 12, 3 resimden 3.
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Fan Assembly Replacement, Reposition the eyepiece trim: adım 13, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement, Reposition the eyepiece trim: adım 13, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement, Reposition the eyepiece trim: adım 13, 3 resimden 3.
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Fan Assembly Replacement, Disconnect the face sensor: adım 14, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement, Disconnect the face sensor: adım 14, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement, Disconnect the face sensor: adım 14, 3 resimden 3.
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Fan Assembly Replacement: adım 15, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Fan Assembly Replacement, Remove the eyepiece trim: adım 16, 1 resimden 1.
    • Remove the eyepiece trim.
  17. Meta Quest 2 Fan Assembly Replacement, Reassembly note: adım 17, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement, Reassembly note: adım 17, 2 resimden 2.
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Fan Assembly Replacement, Reassembly note: adım 18, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement, Reassembly note: adım 18, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement, Reassembly note: adım 18, 3 resimden 3.
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  19. Meta Quest 2 Fan Assembly Replacement, Remove the front cover screws: adım 19, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement, Remove the front cover screws: adım 19, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement, Remove the front cover screws: adım 19, 3 resimden 3.
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  20. Meta Quest 2 Fan Assembly Replacement, Release the front cover clips: adım 20, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement, Release the front cover clips: adım 20, 2 resimden 2.
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  21. Meta Quest 2 Fan Assembly Replacement: adım 21, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement: adım 21, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement: adım 21, 3 resimden 3.
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  22. Meta Quest 2 Fan Assembly Replacement, Remove the front cover: adım 22, 1 resimden 1.
    • Remove the front cover.
  23. Meta Quest 2 Fan Assembly Replacement, Disconnect the top right antenna: adım 23, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement, Disconnect the top right antenna: adım 23, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement, Disconnect the top right antenna: adım 23, 3 resimden 3.
    • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
    • Lift the antenna connector straight up to disconnect it.
    • Guide the antenna cable out of its metal clip holding it in place.
  24. Meta Quest 2 Fan Assembly Replacement, Remove the battery cable bracket: adım 24, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
    • One 4.4 mm‑long screw
    • Two 2.3 mm‑long screws
  25. Meta Quest 2 Fan Assembly Replacement: adım 25, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement: adım 25, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement: adım 25, 3 resimden 3.
    • Use tweezers or your fingers to grasp the battery cable bracket.
    • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
    • Remove the battery cable bracket.
  26. Meta Quest 2 Fan Assembly Replacement, Disconnect the battery: adım 26, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement, Disconnect the battery: adım 26, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
    • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
  27. Meta Quest 2 Fan Assembly Replacement, Disconnect the antenna: adım 27, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement, Disconnect the antenna: adım 27, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement, Disconnect the antenna: adım 27, 3 resimden 3.
    • Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
  28. Meta Quest 2 Fan Assembly Replacement, Loosen the front antenna assembly: adım 28, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement, Loosen the front antenna assembly: adım 28, 2 resimden 2.
    • Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
    • Four 4.4 mm‑long screws
    • Two 4.8 mm‑long screws
    • Two 10.7 mm‑long screws
  29. Meta Quest 2 Fan Assembly Replacement: adım 29, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement: adım 29, 2 resimden 2.
    • Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
  30. Meta Quest 2 Fan Assembly Replacement: adım 30, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement: adım 30, 2 resimden 2.
    • Use tweezers to unclip the antenna cable from its metal clip.
  31. Meta Quest 2 Fan Assembly Replacement, Remove the front antenna assembly: adım 31, 1 resimden 1.
    • Remove the front antenna assembly.
  32. Meta Quest 2 Fan Assembly Replacement, Disconnect the fan: adım 32, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement, Disconnect the fan: adım 32, 2 resimden 2.
    • Use tweezers to grab the fan connector and carefully slide it out of its socket.
  33. Meta Quest 2 Fan Assembly Replacement, Loosen the LED flex cable: adım 33, 2 resimden 1. Meta Quest 2 Fan Assembly Replacement, Loosen the LED flex cable: adım 33, 2 resimden 2.
    • Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
  34. Meta Quest 2 Fan Assembly Replacement, Remove the fan assembly: adım 34, 1 resimden 1.
    • Remove the two screws securing the fan assembly to the headset:
    • One 4.4 mm‑long Phillips screw
    • One 3.6 mm‑long Torx T2 screw
  35. Meta Quest 2 Fan Assembly Replacement: adım 35, 3 resimden 1. Meta Quest 2 Fan Assembly Replacement: adım 35, 3 resimden 2. Meta Quest 2 Fan Assembly Replacement: adım 35, 3 resimden 3.
    • Lift the fan assembly and remove it.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
310.208 İtibar
701 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.648 adet Kılavuz yazıldı
2Kılavuz Yorumları
Amazing guide!! I would never have tried to replace the internal fan without this concise walkthrough. The photos of each step and half-step of the process were extremely helpful. The extra tidbits on the trouble areas helped prevent some serious headache.
Standup job!
For.The.Tech.Of.It - Yanıt
Great guide but I didn't need to replace the fan in the end - a screw had worked loose and lodged in the fan. Cheap fix 🙂
MisterPriscilla - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 106
Son 30 gün: 341
Her zaman: 5,450
