Ana içeriğe geç
Meta Quest 2 Front Antenna Assembly Replacement
Neye ihtiyacın var
  1. Meta Quest 2 Front Antenna Assembly Replacement, Power off your Meta Quest 2: adım 1, 1 resimden 1.
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Front Antenna Assembly Replacement, Remove the facial interface: adım 2, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Remove the facial interface: adım 2, 2 resimden 2.
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Front Antenna Assembly Replacement: adım 3, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement: adım 3, 2 resimden 2.
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Front Antenna Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Front Antenna Assembly Replacement, Unclip the side straps: adım 5, 3 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Unclip the side straps: adım 5, 3 resimden 2. Meta Quest 2 Front Antenna Assembly Replacement, Unclip the side straps: adım 5, 3 resimden 3.
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Front Antenna Assembly Replacement: adım 6, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement: adım 6, 2 resimden 2.
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Front Antenna Assembly Replacement, Remove the top strap: adım 7, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Remove the top strap: adım 7, 2 resimden 2.
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Front Antenna Assembly Replacement, Remove the head strap: adım 8, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Remove the head strap: adım 8, 2 resimden 2.
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Front Antenna Assembly Replacement, Remove the eyepiece trim screws: adım 9, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Remove the eyepiece trim screws: adım 9, 2 resimden 2.
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Front Antenna Assembly Replacement, Release the eyepiece trim clips: adım 10, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Release the eyepiece trim clips: adım 10, 2 resimden 2.
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Front Antenna Assembly Replacement: adım 11, 3 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement: adım 11, 3 resimden 2. Meta Quest 2 Front Antenna Assembly Replacement: adım 11, 3 resimden 3.
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Front Antenna Assembly Replacement: adım 12, 3 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement: adım 12, 3 resimden 2. Meta Quest 2 Front Antenna Assembly Replacement: adım 12, 3 resimden 3.
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Front Antenna Assembly Replacement, Reposition the eyepiece trim: adım 13, 3 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Reposition the eyepiece trim: adım 13, 3 resimden 2. Meta Quest 2 Front Antenna Assembly Replacement, Reposition the eyepiece trim: adım 13, 3 resimden 3.
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Front Antenna Assembly Replacement, Disconnect the face sensor: adım 14, 3 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Disconnect the face sensor: adım 14, 3 resimden 2. Meta Quest 2 Front Antenna Assembly Replacement, Disconnect the face sensor: adım 14, 3 resimden 3.
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Front Antenna Assembly Replacement: adım 15, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Front Antenna Assembly Replacement, Remove the eyepiece trim: adım 16, 1 resimden 1.
    • Remove the eyepiece trim.
  17. Meta Quest 2 Front Antenna Assembly Replacement, Reassembly note: adım 17, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Reassembly note: adım 17, 2 resimden 2.
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Front Antenna Assembly Replacement, Reassembly note: adım 18, 3 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Reassembly note: adım 18, 3 resimden 2. Meta Quest 2 Front Antenna Assembly Replacement, Reassembly note: adım 18, 3 resimden 3.
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  19. Meta Quest 2 Front Antenna Assembly Replacement, Remove the front cover screws: adım 19, 3 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Remove the front cover screws: adım 19, 3 resimden 2. Meta Quest 2 Front Antenna Assembly Replacement, Remove the front cover screws: adım 19, 3 resimden 3.
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  20. Meta Quest 2 Front Antenna Assembly Replacement, Release the front cover clips: adım 20, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Release the front cover clips: adım 20, 2 resimden 2.
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  21. Meta Quest 2 Front Antenna Assembly Replacement: adım 21, 3 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement: adım 21, 3 resimden 2. Meta Quest 2 Front Antenna Assembly Replacement: adım 21, 3 resimden 3.
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  22. Meta Quest 2 Front Antenna Assembly Replacement, Remove the front cover: adım 22, 1 resimden 1.
    • Remove the front cover.
  23. Meta Quest 2 Front Antenna Assembly Replacement, Disconnect the top right antenna: adım 23, 3 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Disconnect the top right antenna: adım 23, 3 resimden 2. Meta Quest 2 Front Antenna Assembly Replacement, Disconnect the top right antenna: adım 23, 3 resimden 3.
    • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
    • Lift the antenna connector straight up to disconnect it.
    • Guide the antenna cable out of its metal clip holding it in place.
  24. Meta Quest 2 Front Antenna Assembly Replacement, Remove the battery cable bracket: adım 24, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
    • One 4.4 mm‑long screw
    • Two 2.3 mm‑long screws
  25. Meta Quest 2 Front Antenna Assembly Replacement: adım 25, 3 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement: adım 25, 3 resimden 2. Meta Quest 2 Front Antenna Assembly Replacement: adım 25, 3 resimden 3.
    • Use tweezers or your fingers to grasp the battery cable bracket.
    • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
    • Remove the battery cable bracket.
  26. Meta Quest 2 Front Antenna Assembly Replacement, Disconnect the battery: adım 26, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Disconnect the battery: adım 26, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
    • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
  27. Meta Quest 2 Front Antenna Assembly Replacement, Disconnect the antenna: adım 27, 3 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Disconnect the antenna: adım 27, 3 resimden 2. Meta Quest 2 Front Antenna Assembly Replacement, Disconnect the antenna: adım 27, 3 resimden 3.
    • Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
  28. Meta Quest 2 Front Antenna Assembly Replacement, Loosen the front antenna assembly: adım 28, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement, Loosen the front antenna assembly: adım 28, 2 resimden 2.
    • Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
    • Four 4.4 mm‑long screws
    • Two 4.8 mm‑long screws
    • Two 10.7 mm‑long screws
  29. Meta Quest 2 Front Antenna Assembly Replacement: adım 29, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement: adım 29, 2 resimden 2.
    • Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
  30. Meta Quest 2 Front Antenna Assembly Replacement: adım 30, 2 resimden 1. Meta Quest 2 Front Antenna Assembly Replacement: adım 30, 2 resimden 2.
    • Use tweezers to unclip the antenna cable from its metal clip.
  31. Meta Quest 2 Front Antenna Assembly Replacement, Remove the front antenna assembly: adım 31, 1 resimden 1.
    • Remove the front antenna assembly.
Sonuç
Arthur Shi
283.802 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 37
Her zaman: 596
