Giriş
Follow this guide to replace either or both of the lower cameras in front of your Meta Quest 2 headset.
This guide shows how to remove the lower right camera as you're looking at the front of the Meta Quest 2. Removing the lower left camera follows a similar procedure.
Note: You'll need a long PH00 bit or a dedicated PH00 screwdriver to remove some recessed screws.
Neye ihtiyacın var
Hold the power button for three seconds to fully turn off your headset.
Grasp and pull on the nose section of the facial interface to unclip it from the headset.
Use your fingers to grasp the right strap near the headset.
Peel the right strap away from the headset arm to unclip it.
Unthread the top strap from its bracket.
Remove the head strap.
Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
Set the trim down on your work surface, making sure not to strain the cable.
Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
Use a spudger to press the lock tab down towards the cable to lock it in place.
Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
One recessed in the top-left corner
One recessed in the top-right corner
Three along the lower edge
Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
Pry with the opening pick to release the front cover clips.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
Lift the antenna connector straight up to disconnect it.
Guide the antenna cable out of its metal clip holding it in place.
Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
One 4.4 mm‑long screw
Two 2.3 mm‑long screws
Use a spudger to pry up and disconnect the battery press connector from the motherboard.
Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
Four 4.4 mm‑long screws
Two 4.8 mm‑long screws
Two 10.7 mm‑long screws
Use a spudger to pry up and disconnect the lower camera connector.
Slide an opening pick under the camera cable to loosen it from the headset.
2 farklı kişi bu kılavuzu tamamladı.
