Giriş
Follow these steps to remove or replace the power switch in a MiTM CM1400HDEC1 2017 electric pressure washer.
This repair requires you to work in a small space next to a large capacitor. Don’t remove the insulated wires attached to the capacitor unless you have the tools and the knowledge required to safely discharge it.
Neye ihtiyacın var
Remove the four 59.2 mm-long 4 mm hex socket bolts from the electrical box.
Carefully pull the electrical box away from the engine until you have enough space to work inside it, making sure not to strain the cables that are still connected inside.
Disconnect the four wires running to the backside of the power switch.
Use a flathead screwdriver or a pry tool to pry the power switch away from the electrical box.
