Ana içeriğe geç
Micro-USB Port Replacement
Neye ihtiyacın var
    1. Micro-USB Port Replacement, Back Plate: adım 1, 2 resimden 1. Micro-USB Port Replacement, Back Plate: adım 1, 2 resimden 2.
      • Unscrew the four 3.4 mm flat head screws
      FixBot'a Sor
      Yorum Ekle
    2. Micro-USB Port Replacement: adım 2, 1 resimden 1.
      • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
      FixBot'a Sor
      Yorum Ekle
    1. Micro-USB Port Replacement, Lithium Battery: adım 3, 1 resimden 1.
      • If not replacing lithium battery, skip down two steps.
      • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
      FixBot'a Sor
      Yorum Ekle
    2. Micro-USB Port Replacement: adım 4, 1 resimden 1.
      • Desolder the battery connections from the motherboard. Learn how to solder components here!
      FixBot'a Sor
      Yorum Ekle
    1. Micro-USB Port Replacement, Motherboard: adım 5, 1 resimden 1.
      • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
      FixBot'a Sor
      Yorum Ekle
    2. Micro-USB Port Replacement: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
      FixBot'a Sor
      Yorum Ekle
    3. Micro-USB Port Replacement: adım 7, 1 resimden 1.
      • Use PH00 screwdriver to remove 5.2mm Phillips head screw
      FixBot'a Sor
      Yorum Ekle
    4. Micro-USB Port Replacement: adım 8, 3 resimden 1. Micro-USB Port Replacement: adım 8, 3 resimden 2. Micro-USB Port Replacement: adım 8, 3 resimden 3.
      • Use ESD safe tweezers to remove the gold ribbon cable.
      • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Micro-USB Port Replacement: adım 9, 2 resimden 1. Micro-USB Port Replacement: adım 9, 2 resimden 2.
      • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
      • You can now access the parts and pieces on the bottom of, and below the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Micro-USB Port Replacement, Micro-USB Port: adım 10, 1 resimden 1.
      • Locate the four main soldering points marked in red.
      • Be aware of the five additional soldered pins marked by the blue arrow.
      FixBot'a Sor
      Yorum Ekle
    2. Micro-USB Port Replacement: adım 11, 3 resimden 1. Micro-USB Port Replacement: adım 11, 3 resimden 2. Micro-USB Port Replacement: adım 11, 3 resimden 3.
      • Begin to desolder the points pointed out in the last step.
      • Use the soldering wick to help remove the solder.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Michael Miller
281 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S3G3
4 Üyeler
16 adet Kılavuz yazıldı
1Rehber Yorum
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
amupis232389 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 23
Son 30 gün: 86
Her zaman: 18,398
