Ana içeriğe geç
Microsoft Surface 2 Screen Replacement
Neye ihtiyacın var
  1. Microsoft Surface 2 Screen Replacement, Screen: adım 1, 3 resimden 1. Microsoft Surface 2 Screen Replacement, Screen: adım 1, 3 resimden 2. Microsoft Surface 2 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
    • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
    • Avoid touching the metal end of the gun. It will be very hot and can burn you.
    • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
    • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
    FixBot'a Sor
    Yorum Ekle
  2. Microsoft Surface 2 Screen Replacement: adım 2, 3 resimden 1. Microsoft Surface 2 Screen Replacement: adım 2, 3 resimden 2. Microsoft Surface 2 Screen Replacement: adım 2, 3 resimden 3.
    • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
    • Use a plastic spudger to pry the retaining clip away from the display cable.
    • The ribbon cable may be glued to the motherboard.
    • Carefully pull the ribbon cable from its socket on the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
EG1
612 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Wollert Spring 2016 USF Tampa, Team 3-1, Wollert Spring 2016 üyesi
USFT-WOLLERT-S16S3G1
4 Üyeler
5 adet Kılavuz yazıldı
10Kılavuz Yorumları
hello, i try to follow your tutorial, without succes. threre is one cable ribon or three?
sophie delalieux - Yanıt Paylaş
This tutorial needs more photos. The part where you unclip the cable from the board is not well illustrated (quite easy to damage the socket by pulling the cable too hard instead of unclamping first)
Matthew Schwantes - Yanıt Paylaş
While this guide is essentially effective, it fails to mention one important aspect of the repair. The transceiver board that is mounted to the back of the LCD/Digitizer assembly needs to be transferred to the new screen. It is held in place by three T2 screws, two push clips, and two ribbon cables. This is, of course, in the event the replacement screen doesn’t include the transceiver (everyone I have received doesn’t). Otherwise, it is a great tutorial.
Christopher Janes - Yanıt Paylaş
did you figure out how to replace the transceiver board? I am in the same position. When I connect just what the directions say, the screen turns on but had no touch capabilities. But when I connect everything, I have nothing but a black screen. Got any tips?
Bob Burgers - Yanıt Paylaş
I have issues with touch capabilities too… any solutions?
Jack Perdue - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 24
Son 30 gün: 86
Her zaman: 17,259
